XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » Question regarding turning the car off
      06-01-2011, 01:07 PM   #23
raleedy
Drives: E92 328i MY 2008 (ED 11/14/07)
Originally Posted by 509trooper View Post
I'm curious, if the start stop button is depressed one and you exit the vehicle with the key FOB and get some distance from the vehicle will that also shut off the electricity?
No. But it will eventually shut itself off.
raleedy is offline   United_States
      06-01-2011, 01:09 PM   #24
raleedy
Originally Posted by caesardog View Post
Try holding the button for more than 1 second. That shuts everything down. Just a longer press.
You can hold it down until hell freezes over. BMW has eliminated this feature.
      10-21-2011, 11:41 AM   #25
walendvay
Drives: '11 F25 28i
The wipers move when not in use for a while in an effort to prevent the blades from sticking to the windows. this is by design.
walendvay is offline   Reply With Quote
      10-21-2011, 02:52 PM   #26
TuffLittleUnit
Drives: X3 xDrive 20d SE
Another time saver for cars with the auto box is that pressing the on/off button automatically switches the gearbox to <P> mode - you don't need to do this first. Might be common sense to many but I've got years of habit of putting the car in neutral before turning the engine off.
On a related theme, does anyone know if keeping hold assist on all the time has any impact on economy or general wear and tear?
X3 xDrive20d SE, Auto, Space Grey/Oyster, Cold weather pack (heated seats front/rear, heated steering wheel, through load), Business loudspeaker system, Electric lumbar support, Voice control system + Bluetooth prep.
TuffLittleUnit is offline   United Kingdom
      10-21-2011, 02:55 PM   #27
walendvay
Drives: '11 F25 28i
I wouldn't think so. Hold assist (auto park) simply applies the brakes (the hydraulic brakes via ABS) rather than the parking brake. It's the same as sitting at a traffic light with your foot on the brake.
      10-21-2011, 04:50 PM   #28
ILuvMy335i
ILuvMy335i's Avatar
Drives: 2011 X3 3.0d Msport
Winner!
I had a Golf 5 GTI 5 years ago that used to do this for the same reason. Its the same with the x3.
F25 X3 3.0 d MSport
ILuvMy335i is offline   Reply With Quote
      10-23-2011, 09:31 PM   #29
caz681
Drives: 2011 X3 Xdrive35i
My 2010 Audi A4 does this as well. If you think about it, your wipers spend most of the time in the Off position (unless you live in Seattle). The rubber will eventually get misshapen on the side which is constantly pressed against the window. This helps prevent that from happening.
It's a German thing, and it's a good thing.
caz681 is offline   Reply With Quote
Forum Jump
