FORUMS
- 5
| XBimmers | BMW X3 Forum » Best time to fill up the tank |
| 05-22-2011, 08:07 PM | #1 |
All,
I am at half tank now since picking up the X3 and trying to figure out when will be the best time to fill the tank usually on my x3. Is it best to fill the car @ half tank, quarter of a tank etc? Is there a best time/level? |
| 05-22-2011, 08:47 PM | #4 |
Anytime it's convenient, as long as you don't risk running out of fuel. Modern, high-tech engines, especially the N55, can be damaged by being allowed to run down to an empty tank. Allowing air to enter fuel system can result in damage to the LPFP (low pressure fuel pump) the infamous HPFP (high pressure fuel pump), the engine's exhaust valves, and the exhaust O2 sensors because of the excess O2 present as the engine runs dry.
I never like to see the gauge get below 1/8 tank. I haven't seen the "low fuel warning" yet, but I suspect it will trigger at between 1 and 2 gallons remaining. |
| 05-22-2011, 08:50 PM | #6 |
![]() Drives: F25 35i Mineral Silver/Black Join Date: May 2008
Ok, I try never to go below 1/2 tank for safety. May sou d paranoid, bu it's mattered more than once before.
Folks used to talk about it being a good idea to regularly take it down close to zero to consume sediments at the bottom of the take to keep the from building up over time. Any truth to that? Applicable to our current vehicles and fuel?
| 05-22-2011, 08:50 PM | #7 | |
| 05-22-2011, 08:58 PM | #8 |
Yep: If you run a X3 dry, you might as well just leave it parked by the side of the road with a "FOR SALE - BEST OFFER" sign attached. The engine, transmission, transfer case, all four axles, exhaust system, brakes and the hood ornament will all be toast. It's almost as bad as getting spray car wash soap on your aluminum intercooler.
| 05-23-2011, 12:16 AM | #13 |
For what it's worth, I would disagree with that comment ("best to fill it before the gas runs out")
- even when you almost run out of gas, the X3 keeps going - at least for the older X3s.I ran the old E83 down to less than "20 miles remaining", well past the low fuel warning sign, several times. Once in particular I actually reached "2 miles remaining" (for the critics, I was on the State thruway, with no exits, and the state troopers closed off the only service center on that stretch)! While I do not recommend anyone try this, I can say that at all of these times, there was no deterioration of performance or any ill-effects to the X3. I have no way to confirm the F25 will behave similarly (and I hopefully will never have to find out). |
| 05-23-2011, 12:49 AM | #14 | |
The LPFP is cooled by fuel and the HPFP is lubricated by fuel. The O2 sensors can be damaged by one severe overheat cycle, which can easily happen if the mixture becomes very lean as you run out of fuel. Although it's counter intuitive, less fuel actually means a much hotter combustion process (too much oxygen). |
| 05-23-2011, 01:13 AM | #15 |
So is it bad to wait and fill up the car when the gas light (30-50 miles left) turns on? Its not like there aren't any gas stations close to my house but I rather fill up my car once a week vs twice or more.
| 05-23-2011, 01:37 AM | #16 | |
You can see "exactly" how much is in each part of the tank to 1/10L by going into the "secret" menu on the dash. The one where you have to enter part of your VIN
![]() BMW X3 (F25) xDrive20d SE . . titanium silver . . titanium front grille . . 309s . . xline . . xenons . . black leather . . alu trim . . professional multimedia package . . dynamic package . . climate package . . electric seats . . folding mirrors . . servotronic steering . . DAB radio . . business speakers . . sun protection glass . . split rear seats . . |
| 05-23-2011, 03:31 AM | #17 | |
2001 Audi A6 Allroad 2.7T (C5); 2005 Audi A6 4.2 Quattro (C6); 2005 BMW X5 4.4i (E53); 2008 BMW 535xi Sports Wagon (E61); 2011 BMW X3 xDrive35i (F25); 2009 Audi A4 3.2 Quattro Prestige (B8)
| 05-23-2011, 04:53 AM | #19 | ||
| 05-23-2011, 10:54 AM | #20 | |
I know it sounds counterintuitive but the fuel actually runs through the motor of electric fuel pumps. As such they are cooled and lubricated by the fuel. If you run dry your pump is running with no lube and coolant. I try to keep my tank above 1/4. |
| Bookmarks |
