05-05-2011, 12:47 PM | #1 |
Rep 138
Drives: 2011 BMW X3 35i Space Gray
Mud flap question
BMW installed my flaps, but they pull away about 1/8" way from the side of the car. There is adhesive tape there, but they won't hold. Is this something others have seen? They washed the car immediately after the install, so that could be the issue. Or, everyone's might look like this. Maybe I'm being overly picky?
05-05-2011, 02:28 PM | #3 |
Rep 5,115
Installed mine myself; zero gap. See my pics here:
http://x3.xbimmers.com/forums/showth...ight=mud+flaps Personally, for the labor they charge, I'd take it back in, but that's me. Dave
05-05-2011, 02:43 PM | #4 |
Rep 138
I'm having them take them off. They don't look good at all. This has taken forever today.
05-05-2011, 03:40 PM | #5 |
Rep 138
They tried to get them tighter by taking them off and doing some fitting work. No dice. They looked good for 5 minutes, then the tape broke free and the gap was there again. I'm not sure if I got a bad set of flaps or a bad installer, but this isn't working. They said they wanted to put some epoxy on them....which I quickly said "um....no way."
They're going to take them off when I can get back there. I'm sure the wholes they made can be plugged with little difficulty. The whole thing was really time consuming and frustrating though. Look into this on your own a little further if you decide to have these installed. I know other forum members have had better luck than me. |
05-06-2011, 06:35 AM | #6 |
Rep 169
I had the mud flaps installed yesterday too. The dealer said there was a problem with the back ones not fitting tightly. They showed me the problem and, sure enough, they were loose. Long story short, the dealer used a different pin/grommet combo which tightened them up and eliminated the problem. All it took was a little ingenuity.
05-06-2011, 06:42 AM | #7 | |
Rep 138
09-11-2011, 08:34 AM | #8 |
Rep 35
I recently fitted mud flaps to my X3 and found that they didn't fit as well as I would have expected of OE BMW parts.
I fitted the fronts first, using the correct mounting holes and the tape that is fitted to the flaps and assumed (yes, I know!) that they would be a perfect fit However, in a very short time the tape pulled away from the wheel arch leaving a gap of maybe as much as a quarter of an inch! Being aware of this when I fitted the rears I approached the task differently and made sure to correct any of the fixing points that pulled the flaps away from the wheel arch. I ended up having to use washers as spacers on the fixing under the car on the left side flap and on the right side I had to re-drill the mounting hole under the car. By doing this I was able to get the flaps to fit perfectly. Now all I have to do is take off the front ones and refit them using the same approach. |
09-11-2011, 08:40 AM | #9 | |
Rep 198
Previous: 2011 X3 2.0d xLine Previous: 2015 X3 LCI 3.0d xLine Current: 2018 530e 2L M-Sport I-Performance |
09-11-2011, 08:52 AM | #10 |
Rep 1,089
Having fitted the rears myself I can confirm the tape is as good as a chocolate fireguard. I dont think the tape is even sticking but mine fit snugly and will do front when I get chance
BMW F25 X3 xDRIVE 20d SE Black Sapphire | Oyster Leather | Fineline Sienna Wood | 307 V Spokes | Auto | Prof Multimedia Package | xLine Package | Xenons | Business Radio | Sports Steering Wheel | Sports Seats | Panoramic Sunroof | Sun Protection Glass | Sun Blinds | Folding Ext. Mirrors + Titanium Grille | Chrome Exhaust Trim | Mudflaps |
09-11-2011, 08:54 AM | #11 |
Rep 424
I have the same problem with the tape not holding as it should.
I’m waiting to see if there will be a re-design or some sort of TSB. I’m amazed that a BMW part specifically designed for the F25 has such a poor fit. |
09-11-2011, 09:46 AM | #12 |
Rep 198
Those of you that did a self fit, did you need to remove the wheels?
09-11-2011, 09:48 AM | #13 |
Rep 12,276
Since you paid the dealer to install them, and your problem seems to be an installment problem - I would tell the dealer that you want a new set installed, as the job is not satisfactory.
I think it is bad luck to be superstitious |
09-11-2011, 02:12 PM | #14 |
Rep 1,089
Not on rears (meant to be hardest) with the right tool it was a bit fiddly but easy enough
09-18-2011, 10:53 AM | #15 |
Rep 332
what tool do u need to fit the mud flaps?
it's here!!!
09-18-2011, 11:38 AM | #16 |
Rep 1,089
Used a ratchet screwdriver from Wilkos that cost less than a fiver (perfect for those hard to reach back screws and no need to take rears wheels off), plus also used small spanner.
Type in "Wilkos ratchet screwdriver" into google and it will pop up as first organic listing (13 in 1 tool with orange handle) - doubtfull the tool will be used again but cant complain at £4.97.
