FORUMS
- 5
| XBimmers | BMW X3 Forum » Fuel Quality (US) |
| 03-27-2011, 10:00 AM | #2 | |
TK-421
"Required fuel Super Premium Gasoline/AKI 91 or AKI 89 BMW recommends AKI 91 or 89. Gasoline with lower AKI The minimum AKI Rating is 89. If you use gasoline with this minimum AKI Rating, the engine may produce knocking sounds when starting at high outside temperatures. This has no effect on the engine life." In OR, our premium is 92. And that's what I use. Use 89 at your own risk. |
| 03-27-2011, 10:15 AM | #4 |
TK-421
That's the safe bet. Some people will tell you that you only need to use premium if you have a turbo, but that's BS. Your car will thank you for it.
| 03-27-2011, 12:40 PM | #5 |
![]() Drives: F25 35i Mineral Silver/Black Join Date: May 2008
Use the highest available. This engine will appreciate it. Usually $1.75 difference per tank. If you can afford the car and a Morning latte, you can probably cover the $2 per tank. You get a bit better mileage, when you want to zip it zips better, and it burns a bit cleaner. But, if you wanna save about $104 dollars a year, then the lower grade is for you.
| 03-27-2011, 12:51 PM | #6 |
Pygocentrus Piraya
I use 91 or 93...depending on which station I'm at.
kozzi
![]() 2011 BMW F25 35i Deep Sea Blue Metallic/Nevada Mojave/Brushed Aluminum/SAP/DHP/309 Run-Flats |
| 03-27-2011, 03:53 PM | #7 |
![]() Drives: 2012 E82 135i MSport 6MT Join Date: Apr 2007
I use at least 91 in my BMWs, and used 94 in my previously owned M3.
2012 135i E82 MSport 6MT Jet Black
Previous BMWs - 2012 135i MSport LMB DCT(sold), 2011 X3 35i MSport VR (sold), 2009 M3 Sedan AW (sold), 2008 535xi MSport AW (sold), 2007 328xiT Barbera (sold), plus 11 others in the 70s & 80s. |
| 03-27-2011, 04:11 PM | #8 |
Do you use the same RON octane ratings as the UK? Our premium is 97-99. Why is yours only 92?
Is that why we're paying so much more for our fuel over here? ![]()
![]() BMW X3 (F25) xDrive20d SE . . titanium silver . . titanium front grille . . 309s . . xline . . xenons . . black leather . . alu trim . . professional multimedia package . . dynamic package . . climate package . . electric seats . . folding mirrors . . servotronic steering . . DAB radio . . business speakers . . sun protection glass . . split rear seats . . |
| 03-27-2011, 06:16 PM | #10 |
Rider and driver
Drives: 2011 Black X35i Rides: K1300GT Join Date: Feb 2011
RON=Research Octane Number. Basically, a calculated value. Generally a higher number
MOT=Motor OcTane. Variable compression head motor that is indexed to show real octane performance with an internal combustion engine. Generally a lower number. AKI= Anti-Knock Index. RON*MOT/2 (average) Method used in the U.S. 91 AKI is generally 95 RON, but as it depends on the MOT value, it could change. Nice way to advertise octane numbers, but keeps everyone in the dark as to what's really happening. If you hear knock, go to the next higher grade. ![]()
2011 X3 35i
Black Saphire - Nevada Mojave - Y Spoke 308 - Premium Sound - Navigation I work for Keyser Söze |
| 03-28-2011, 08:29 AM | #13 |
Stopped at the local Mobil and had to go with 93 for the first fill up as 91 was not avialable. I did notice on the pump it said contains 10% ethanol. Even if it is 93 octane, should I stay away from that Mobil and the ethanol content as I noticed in the manual it says that? Thoughts?
| 03-28-2011, 10:46 AM | #16 |
Can you guys in the states even find non ethanol gas anymore? It's pretty much impossible to find stations without a "up to 10% ethanol" sticker on the pumps.
Also the price difference between the highest grade and lowest grade of gas is minuscule even if you add it up over a year. It's the same reason why I never understood people who buy a hybrid "for the fuel savings." The savings over using just a normal petrol or diesel engine takes years in order to recuperate the upfront costs of a hybrid. I can understand someone wanting to get a hybrid because it's better for the environment since they're burning less fossil fuel and price for fuel doesn't represent the true cost of production and harm towards the environment but not when someone buys it for the so called money savings. |
| 03-28-2011, 11:15 AM | #17 | |
| 03-28-2011, 12:09 PM | #18 | |
FYI - The actual amount of energy you purchase in a gallon of fuel: Diesel: 130,000 Btu/gal Gasoline: 115,000 Btu/gal. Gasoline/ethanol(10%) blend: 111,070 Btu/gal. Gasoline/ethanol (15%) blend: 109,105 Btu/gal. Current (Gasoline/ 10% ethanol) blends typically yield a 4 to 5% reduction in gas mileage compared to pure gasoline. The new “ 15% blend” will reduce mileage by approximately 6% minimum. The major contributor to the “Growth Energy” lobby is Archer Daniels Midland Co. The day after the ethanol regulations were changed to 15% ADM stock rose 2%. Coincidentally, exactly the same percentage that the new (15%) blend will cost consumers in the U.S. because of the reduced gas mileage they will be seeing. |
| 03-28-2011, 12:33 PM | #20 | |
Anyway, I'm just stating the facts. Draw your own conclusions. |
| 03-28-2011, 04:18 PM | #21 | |
http://www.autoblog.com/2011/02/22/r...lock-e15-fuel/ |
| 03-29-2011, 12:39 AM | #22 | |
Somehow, the notion of stretching auto fuel by raising food prices, and using more net energy to distill ethanol than it provides (even if that energy is from electricity) does not seem very smart from any point of view, except that of the grain companies who will turn a tidy profit. Last edited by Lotus7; 03-29-2011 at 01:07 AM. |
| Bookmarks |
