FORUMS
- 5
| XBimmers | BMW X3 Forum » Sport Program (transmission) Specs |
| 03-15-2011, 11:32 AM | #1 |
Hey. I did a search, but came up empty -- might be poor choice of search terms. If so, I appologise...
I took delivery of a new X3 just a week ago (for my wife, so I get limited driving opportunities). I was out and about with it and thought I'd put it into manual mode at a stoplight for a bit of fun so slid the shifter over to the left. Light turns green and off I go, but I was surprised when the car shifts on it's own around 3k RPM before I could pull the lever back to upshift. This is how I'm introduced to the sport program (or DS) mode. Once back home I look up the feature and see that I have to manually shift at least once before the car will move to manual shift mode. OK, so far so good... but it's got me a bit curious. Just what does DS mode really do? The manual is especially vague -- "This position is recommended for a performance-oriented driving style" -- I've noticed that it seems to keep the RPMs about 1k higher than before and shifts higher. Anything else change? How about the throttle map? |
| 03-15-2011, 11:47 AM | #2 | |
TK-421
I'm not sure about the 28i, but from what I've read switching in M will not put the car into "sport" mode. On my car (35i with SAP and DHP) when I slip the selector to the left the car will rev a little higher but still change gears automatically. If I use the paddles or selector to change the gears, the transmission will stay in the selected gear until it reaches a safety. |
| 03-15-2011, 12:27 PM | #3 | |
Pygocentrus Piraya
kozzi kozzi
kozzi
![]() 2011 BMW F25 35i Deep Sea Blue Metallic/Nevada Mojave/Brushed Aluminum/SAP/DHP/309 Run-Flats |
| 03-15-2011, 01:11 PM | #5 | |
| 03-15-2011, 01:35 PM | #6 | ||
TK-421
| 03-15-2011, 02:24 PM | #7 | |
I don't have the DHP but I do have the SAP optioned on a 35i. One my main factors for the SAP was for the paddle shifters and will most likely be using them more often than not. I've only ever driven a test demo for about 15 mins at a dealership so I don't have much experience with the car but I did notice that it shifted by itself fairly quickly. For comparison my last car (MB C300) only had a SMT and had two modes, casual and sport. When shifting manually in casual the car would rev to around 3-4k before shifting manually and 5k or higher when in sport. How does the 35i work w/o the DHP? Are you able to change the rev limit w/o all the sport or sport+ modes that are included in DHP? |
| 03-15-2011, 02:29 PM | #8 |
Not sure if we're talking about the same thing but perhaps this will answer my questions. I'm not too worried about the damper or split wheel power that comes with the DHP but I am concerned about rev points. Do you happen to know at what rpm the car automatically changes and if you're able to change the rev points in a 35i with SAP and no DHP?
| 03-15-2011, 02:43 PM | #9 | |
Pygocentrus Piraya
kozzi
kozzi
| 03-15-2011, 08:11 PM | #10 |
Rider and driver
Drives: 2011 Black X35i Rides: K1300GT Join Date: Feb 2011
Just adding a data point, FWIW. I have the DHP and sport package. When I move the lever to the left, it changes to sport mode, and is in 7th (not 8th) gear. Shift points change, but I can't say (yet) if its the same as when putting the DHP in Sport mode. Touch the paddles once, and you're in mostly manual mode. I say mostly, because if you're in M7, and you get off the freeway/motorway to a stop, you find yourself in M2 (which isn't a bad thing). I think that's part of the "safety" the other poster was referring to. I don't believe (haven't tested, too new) you get any "assisted" upshifts, you just find that your go pedal isn't effective anymore.
2011 X3 35i
Black Saphire - Nevada Mojave - Y Spoke 308 - Premium Sound - Navigation I work for Keyser Söze |
| 03-15-2011, 09:01 PM | #12 |
![]() Drives: F25 35i Mineral Silver/Black Join Date: May 2008
Moving the shifter to the left puts the transmission only in Sport mode (thereby different than using the DHP buttons that can do more). Moving it left does not put it in manual mode. Using the paddles or tapping the shifter to select a shift puts it in manual mode. You can also enter manual mode by using the paddles with the shifter in the normal drive position.
So, you can configure DHP Sport to change only chassis. Then use DHP to get the chassis to sport while keeping transmission normal to keep high gear available. The bop the shifter left to get the transmission in Sport when you want.
| 03-15-2011, 10:29 PM | #13 |
Pygocentrus Piraya
Never thought about shifting the selector left only changes the transmission. Under the iDrive info and using the DHP...it is still labeled as normal mode. It says nothing about the transmission being changed. It's not really an issue for me either way...I enjoy driving in sport+ for city A to B driving and normal on long drives.
kozzi
| Bookmarks |
