XBimmers | BMW X3 Forum > BMW X3 Forums | F25 (2011 - Current) > Second Generation BMW X3 General Forum » UK Orders
      10-29-2011, 07:40 AM   #969
Stevenuk
Drives: BMW X3 2011
Picked my new X3 up yesterday and i love it!
It feels so much bigger then my car even though its just 40mm wider and 500mm longer!
I only have 2 quick pics i took on my phone but it dosent take great pictures so ill try and do more over the weekend with a better camera.
Stevenuk is offline   United Kingdom
      10-29-2011, 09:32 AM   #970
cooldude00
Drives: x3 2.0d
very nice.. was really tempted for the deep sea blue colour....
it's here!!!
cooldude00 is offline   Reply With Quote
      10-29-2011, 09:52 AM   #971
Stevenuk
Drives: BMW X3 2011
Just a few quick Qustions about the car
1) With the USB connections can you not plug i USB memory stick in which has music on there and listen to that?
2) DVD Playback seems very quiet compaired to the Radio is that normal? If i go from dvd to radio its a huge difference.
3) When someone Calls me it just rings normal is there anyway to change it to the phones ringtone?
Thanks
      10-29-2011, 11:04 AM   #972
VikingOne
VikingOne's Avatar
Drives: BMW X3 2.0D SE
Thanks
1) Yes in the USB socket within the Center Arm Rest, if you put a USB memory stick with MP3's on it will play, under CD&Multimedia\external devices\USB. If the MP3's have embedded Album Art in the MP3 Tag, it will also show the artwork on the iDrive screen
2) Yes DVD play back is very quiet, If am burning my own I increase the DVD burn volume to +80%
3) As far as I know you cannot use your phones ringtone as the bluetooth car ringtone.
UK Order 10 Feb 2011 - picked up 30th Sept 2011
VikingOne is offline   United Kingdom
      10-29-2011, 11:21 AM   #973
Stevenuk
Drives: BMW X3 2011
Thanks for that i thought as much.
When i put a USB Stick in the slot nothing happens as it shows not connected on the screen?Do i have to do something somewhere? The AUX Jack in works fine
      10-29-2011, 01:47 PM   #974
VikingOne
VikingOne's Avatar
Try another USB stick, if then still no joy, suggest a trip to dealer. I think the MP3s need to be less than 320 bit rate. But would still expec it to see the stick.
      10-29-2011, 02:18 PM   #975
tank531
Deckhand
tank531's Avatar
Drives: F25 2.0D SE xDrive (Sep 11)
Thanks
For item 2 - I am still reading the manual front to back and often read interesting details but then can't find them when you need the info. There is a config menu option to balance DVD volume with the usual radio/cd volume - but I can't find the page number. From memory you will need to have a DVD playing then try all the config menu's for DVD you can find and a volume slider will show that can be adjusted to balance the difference you refer to.
tank531 is offline   United Kingdom
      10-29-2011, 02:42 PM   #976
tank531
Deckhand
tank531's Avatar
took another look in the manual and made a mistake - page 171 was what I was thinking but it is not to balance DVD vol, but to balance aux-in vol only
      10-29-2011, 03:01 PM   #977
Stevenuk
Drives: BMW X3 2011
Thanks for your help everyone on the usb and dvd volume.
Ill try a smaller USB stick tommorow as the 1 i used was a 16GB one so might be to big for it maybe?
      10-29-2011, 03:58 PM   #978
JimBeamer
JimBeamer's Avatar
Drives: F25 X3 2.0d SE
Great colour, looks just like mine. I also thought it was bigger than I remember. Congrats and enjoy. :happening:
X3 2.0d SE Ordered W9, Build W38, Deliverd W43, Deep Sea Blue, Black Leather (Sports), Access, Cold Weather, Visibility, Media Pro, Auto, Sun Glass
JimBeamer is offline   England
      10-29-2011, 05:45 PM   #979
Bustofa
Drives: F25 X3 XDrive20D SE
Don't think size will be the problem; I have an 80Gb hard disk plugged in and it plays fine.
Bustofa is offline   United Kingdom
      10-29-2011, 08:25 PM   #980
TuffLittleUnit
Drives: X3 xDrive 20d SE
+1
I'm using an older (USB2.0) WD Passport 320GB drive and it works fine ... better than my iPhone4, actually. It still displays cover art etc and the track listings are in the correct order. Additionally I can browse using the folder structure as well as the usual artist/album etc filters which is pretty useful for me given the way I store my media files.
I've got about 80GB of music, mainly in MP3 at 320Kbps - the initial indexing takes some time but then the car seems to retain this and only takes a few secs to initialise each time I start it up.
I think the drive cost me about £50 from a retail store (Currys/PC World).
The X3 manual advises against using portable HDDs but I suspect this is because the only drives that will work are bus powered (i.e. powered through the USB socket) and the drive might get damaged if the power is just switched off. It's been a long time since it's been necessary to park the HDD heads before switching a drive off so I'll take my chances.
So, my advice is not to get ripped off with high capacity USB flash drives ... get a bus powered HDD.
X3 xDrive20d SE, Auto, Space Grey/Oyster, Cold weather pack (heated seats front/rear, heated steering wheel, through load), Business loudspeaker system, Electric lumbar support, Voice control system + Bluetooth prep.
TuffLittleUnit is offline   United Kingdom
      10-30-2011, 03:42 AM   #981
sfax
sfax's Avatar
Drives: BMW X3 2011 F25
StevenUK - congrats on your new X3, looks really nice - I still haven't seen a DSB in the flesh. I may be getting those alloys for winter tyres and I like them every time I see them.
Re. DVD volume, I don't think it can be adjusted and it's DANGEROUS! The difference is ridiculous. BimmerUK76 had a thread on this.
Re. USB, just to confirm what other people have said, it should work with any size so worth trying a different stick. A USB stick is preferable to the Music Collection which has a lot of flaws. I bought this one which is cheap as chips and had been working well for a few months. I would personally stick to solid state unless you need the extra capacity
https://www.amazon.co.uk/7dayshop-Me...9963776&sr=8-1
      10-30-2011, 04:47 AM   #982
Stevenuk
Drives: BMW X3 2011
Hi i now found a different USB stick and that works fine !? so im glad it is not broke on my car! It must be the ones im using dont like BMW they are Play.com Sticks. I tried a Busbi USB Stick and it worked right away only problem its only 500 MB!. I order that one you linked on you post as that looks great value and you know that USB stick works in your car.
The only difference between the 2 keys is the play.com Stick is FAT32 and the Busbi Stick is just FAT . So no idea if thats why?
      10-30-2011, 09:36 AM   #983
cumbrianlad
Drives: X3 2008
First post on the forum so be gentle with me! Recently discovered this forum and have so far found the content interesting and informative.
Ordered an F25 2.0D last April. This to replace my E83, the contract for which runs out in December. At time of order was informed that i might 'just' get my F25 delivered in time. Given that my dealer knew I was interested in ordering a new one I would have thought a reminder would have been good business in time to meet my dates, but that is another story! Anyway lucky enough that someone cancelled their order because they weren't prepared to wait, so I got their slot which meant delivery was planned for week 49 (mid-dec) thus fitting in with my requirements. Otherwise I'd have been waiting for a March 12 delivery.
Now told delivery will be 21 Nov which just happens to be the start of our two caribbean cruise. Maybe I should let other half cruise on her own and I can enjoy two weeks with my new arrival!
cumbrianlad is offline   Reply With Quote
      10-30-2011, 09:44 AM   #984
AJWilson
AJWilson's Avatar
Welcome and congrats on your order.
BMW F25 X3 xDrive20d SE
Alpine White, Black Leather, HUD, Auto, Pro media, Visibility, Climate Comfort,Storage, Cold weather Packs, Pro Loudspeaker system, Sun Protection Glass, Electric Adjust Front Seats, Reversing Camera with Top View, 19" 309's,Variable Damper Control,Variable sport steering, Sports Seats, Sports Steering Wheel. Re-ordered 27/7/11, Arrived 28/9/11
AJWilson is offline   Scotland
      10-30-2011, 09:46 AM   #985
AJWilson
AJWilson's Avatar
Congrats, looks great in blue
      10-30-2011, 10:34 AM   #986
Rogerbu
Drives: X3 3.0D M Sport, Alpine White
Question to Washy.
Your pictures of your X3 3.0D M Sport show the Normal/Sport DDC switches, but your option list doesn't include VDC. Did you order VDC or did the DDC come as a result of having the Varable Sport Steering on the 3.0D M?
Cheers
Rogerbu is offline   United Kingdom
      10-30-2011, 11:29 AM   #987
washy
washy's Avatar
Drives: M135i/Golf GT convertible
Originally Posted by Rogerbu View Post
Question to Washy.
Cheers
No I didn't order VDC, but the 3.0d comes with the VSS which includes the switch.
On a side note I am sad to report I no longer have my X3. Sadly my other half lost her job in the week and I sold the car back to the dealer. Turned into the most expensive two week car hire ever....
2003 E46 M3 Estoril blue
2006 E90 320d M sport Le Mans blue
2008 E82 125i M sport Alpine white
2008 E88 135i M sport Titanium silver
2013 F21 M135i Estoril blue
washy is offline   United Kingdom
      10-30-2011, 12:38 PM   #988
BIMMER UK 76
BIMMER UK 76's Avatar
Drives: BMW F25 X3 20d SE
Welcome lad, will be interesting to hear your views on the f25 when you get it (pics are a forum mandatory rule). Bit of a dilema re the cruise, I could take your place????
BMW F25 X3 xDRIVE 20d SE
Black Sapphire | Oyster Leather | Fineline Sienna Wood | 307 V Spokes | Auto | Prof Multimedia Package | xLine Package | Xenons | Business Radio | Sports Steering Wheel | Sports Seats | Panoramic Sunroof | Sun Protection Glass | Sun Blinds | Folding Ext. Mirrors + Titanium Grille | Chrome Exhaust Trim | Mudflaps
BIMMER UK 76 is offline   United Kingdom
      10-30-2011, 12:41 PM   #989
BIMMER UK 76
Ouch! How many miles did you clock up? Taking a financial hit was the last thing you needed after your bad news! Hope your missus finds the job of her dreams (cloud, silver lining etc) and then you could go for the 35d, keep your chin up
      10-30-2011, 12:44 PM   #990
BIMMER UK 76
Question to Washy.
Cheers
Another welcome to Roger
That 30d will be awesome, why o why didnt i wait?
What car are you currently driving?
Forum Jump
