05-12-2024, 10:11 AM | #1 |
Rep 221
Synchro design front thrust arm replacement. I am stuck
Hi guys,
All was going well and smooth but after removing all the bolts and everything the front trust arm can not be removed because of the axel being on the way. Anyone got any suggestions? I tried moving the wheel around but not luck. I hope I don’t have to remove the axel to get replace this part. Let me know or if anyone has the manual for it? Last edited by deviation01; 05-12-2024 at 11:11 AM.. |
05-12-2024, 04:51 PM | #4 |
Rep 1,833
Drives: 2022 X3 M40i
Just saw this...yeah need to remove axel nut, turn wheel slightly and slide arm out. Make sure you tighten the nut at ride height on the frame side.
05-12-2024, 09:05 PM | #5 | |
Rep 221
I torqued everything to spec. Took it for a drive and the steering feels buttery smooth. |
05-12-2024, 09:29 PM | #6 | |
Rep 1,833
like this video for visual example. Last edited by Burr001; 05-12-2024 at 09:35 PM.. |
05-12-2024, 09:51 PM | #7 | |
Rep 221
05-12-2024, 10:19 PM | #8 | |
Rep 1,833
Ok how about this...lets say your lying down and I tied a 100lb weight to your nut sack and only measured enough rope so its the shortest... Now you stand up but since the line was only long enough from the height you were lying down and because the line is short and your nuts are being being pulled down by the 100 lbs, you think the extra strain is worth it than to adjust the line to the proper length at standing height? |
5LEEPR_G01508.00 blackops23487.50 |
05-12-2024, 10:28 PM | #9 | |
Rep 221
In all seriousness. Can I reach the nuts and bolts with the wheels on the ground? Basically I have to loosen the bolt now and retighten? Last edited by deviation01; 05-12-2024 at 10:45 PM.. |
5LEEPR_G01508.00 |
05-12-2024, 11:08 PM | #10 | |
Rep 1,833
do you not have a 2nd jack? one to lift the car and one to lift the arm? or use a race ramp or use a tall enough sidewalk curb, your old stack of porn DVD's or use a stack of wood to place under the wheel on both sides after lifting, then lower it and let it sit on the high enough wood stack to crawl under and reach the nut and tighten.... |
05-13-2024, 07:22 AM | #11 | |
Rep 221
05-13-2024, 07:59 AM | #12 | |
Rep 1,833
You have a jack and stands, so place vehicle on jack stands...then take said jack and place under the tire/arm and lift it to what would be/close to ride level and then tighten. if you feel the vehicle lifting off the jack stands you have gone too far and lower it a tad. OMG hahahaha. Last edited by Burr001; 05-13-2024 at 08:06 AM.. |
deviation01126.00 Gr8ZongB58291.50 |
05-13-2024, 08:06 AM | #13 | |
Rep 221
Haha I get that but I was thinking both sides need to be at equal level vs one at the time. I was talking to a mechanical engineer that has done this upgrade as well he said because its a ball bearing the only thing that could cause it advance wear would be improper torque. He has had his for 40k miles and takes the car to the track often. Syncro also confirmed no need. I guess you can call me the forum Guinea pig. |
Burr0013383.00 |
05-13-2024, 08:13 AM | #14 |
Rep 1,833
Bruh...maybe these are a better visual for you?
05-13-2024, 08:18 AM | #15 | |
Rep 1,833
05-13-2024, 08:25 AM | #18 |
Rep 1,833
05-13-2024, 08:43 AM | #19 |
Rep 221
btw I will post a video about this whole experience shortly for people that want to see the step by step but this quote came from Syncro about the topic.
Good question, You can torque at any position, as it is a fully articulating monoball! It does not bind in the same way that rubber does, so it's good for performance as well as air ride guys that change ride height. |
Burr0013383.00 |
05-13-2024, 10:29 AM | #20 | |
Rep 1,833
deviation01126.00 |
