05-04-2024, 11:36 AM | #1 |
Rep 286
I finally figured out the right things to lubricate to eliminate the sunroof Creek when you go over uneven surfaces. It's basically the connection point where the movable portion of the sunroof meets with the static glass in the rear. That whole line has three surfaces that come together. There is an inner soft seal, the ceiling point that is on the movable glass, and the harder ceiling point that is on the fixed glass. I purchased a tube of this German Lube that is specifically for sunroofs and it works great. It was fairly cheap on Amazon as well. I've added pictures that point out the areas that will get rid of the creek.
I applied the grease using my finger and spread enough to where it wasn't gobbed up but was still visible. If you spread it too thin it becomes translucent. I'm sure this will have to be a reapplied in time which is typical with lubricants for seals but it does eliminate the noise. |
05-04-2024, 11:51 AM | #2 |
Rep 1,833
Drives: 2022 X3 M40i
Most people who also installed a chassis brace also eliminated the noise due to chassis flex fyi. Using lube will eliminate noise but not the actual movement when going over uneven roads.
05-04-2024, 12:07 PM | #3 |
Rep 286
05-04-2024, 10:41 PM | #4 |
Rep 132
05-05-2024, 12:25 AM | #5 | |
Rep 437
I had a tremendous amount of noise from those same contact points when my car was brand new and the Sonax GummiPfleger worked for me. It took two applications. I’m always interested to see what people use. People swear by all kinds of products:
But lately what I have been experimenting with is to just clean it with a mild dilution of soapy water. Just a spray bottle with a few drops of dish soap, and an old rag. So far it’s working. But I have the tube of Shin Etsu ready to go for my next experiment if the noise recurs. |
05-05-2024, 10:15 AM | #6 |
Rep 565
It definitely helps a lot. Used to creak every time I pulled out of my driveway before the chassis brace. Now that I have the brace, I do still get a creak out of the sunroof every once in a while, maybe 1 out of 10 times. (my driveway has a dropoff to the street, so I regularly flex the chassis pretty hard when I pull out of the driveway). I think it has to do when the moisture content is just right...anyways I'll prob do this too.
2019 X3 M40i | TU Pump | AA DP | VTT GC | xHP Stage 2 | Dorch ECA | MHD Odin FF | Carbon Black | Adaptive Suspension | M-Sport Rear Diff | 20" staggered
SOLD! 2015 X1 35i | Alpina Trans Tune | Dinan Stage 2 | Bilstein B6 |
05-05-2024, 10:21 AM | #7 | |
Rep 286
05-05-2024, 10:23 AM | #8 |
Rep 565
I was going to try dry silicon lube. Will let everyone know how it works.
05-05-2024, 10:30 AM | #9 |
Rep 4,369
Krytox oil or grease is used by many roof system OEM’s. Only a tiny qty is needed.
Guide what to use and where - https://www.krytox.com/ja/-/media/fi...2569eb61f0b44a |
turbobeagle403.50 |
05-05-2024, 11:28 AM | #10 |
Rep 286
I can save you some time with that. I tried dry silicone spray and it does not last a week. It's too thin and viscous. If you go with silicone I would suggest getting a tube of silicone gel. It's clear and goes on thick but typically in the heat it doesn't hold up well and dissipates.
abbike18717.50 |
05-05-2024, 12:20 PM | #11 |
Deadly
1329
Rep 2,093
Not got a rubber/seal creak, but mine has a metallic noise when open full. I can only imagine some bolt needs tightening but in order to locate any bolts (other than the ones I can see) does anyone have access to that TIS-WIS thing that has the exploded diagrram that might help me locate as many as possible (I'm not in favour of hunting under the lining by taking it off :-).
05-06-2024, 09:57 AM | #12 |
Rep 565
For a real quick and dirty fix...there was a pile of grease in the front of the sliders from years of operation. Some of it was pretty clean. I just took some of that and spread it on the back seal of the glass! Probably best to get some new, and I've got some on the way to grease up the entire thing, but if you are out and about and it's driving you nuts you can do this. Just beware - it's very sticky grease so you'll need to clean your finger pretty well.
dinan5m34371.00 |
