      04-29-2024, 04:46 AM   #1
MikeVix
Drives: X3, M5, Z3
Hello guys,
It’s my first time posting and I’m sorry if the format is weird.
I wanted to share a dyno of my fathers x3 F25 35i.
The car had an cts high flow dp a performance air filter which I don’t recall the name and an intercooler.
We had the car in for a custom tune.
The dyno was a MAHA dyno
The words on the paper are Greek so let me explain
384 hp engine
268 wheel hp
571 Nm
The thing is that I have seen many stage 1 builds here and no one was under 300whp and I’m pretty confused.
What’s your impressions?
      04-29-2024, 06:48 AM   #2
mwat
Drives: E46 M3 & LCI X3 35i M Sport
2016 BMW X3 35i  [0.00]
2001 BMW M3  [0.00]
No tune = minimal gains. DP+IC+Tune should get you to the 320-350whp and 400+ lb/ft TQ
      04-29-2024, 06:51 AM   #3
MikeVix
Drives: X3, M5, Z3
mwat that’s what I find weird it’s supposed to be stage 1 it says 384 engine hp but wheel hp is too low at 268
      04-29-2024, 09:51 AM   #4
mwat
2001 BMW M3  [0.00]
That sounds like a computer calculation that doesn't have anything to do with the Dyno. I'll concede I am no expert and know only a little about dyno's.
HOWEVER. Assuming that this is not an engine dyno the number that you're getting is 268 at the wheels which is probably lower than stock or right about what stock would be. The 384 number seems to be a miscalculation by whatever software the dyno uses. These two numbers would represent a 30% drivetrain loss which is just simply not true for xDrive cars. It's more like half that or less in my research. (12-15% loss based off BMW's numbers)
Somethings not right with the dyno/dyno software, or with the car. My guess is the Dyno/Dyno software. Do you know what stage 1 software it's supposed to be? Has the car been logged with this new tune?
It's tough to say without a baseline as all dyno's read differently, if you can flash back to stock and do a dyno run that'll really tell you the story.
