02-26-2024, 06:41 PM | #1 |
Rep 92
Drives: 21 x3m
Wheel/Tire gurus step inside for tire n00b
Found a deal on a set of Adohan 20x9 / 20x10.5 5x112 30/35 hub 66.6
These should fit correct? What would the best size tire for them be, I'd prefer a 295 or 305 in the rear if possible. I know we are supposed to stay within 1%, but is that 1% vs the 21" tire size or 1% of each other? |
02-26-2024, 09:36 PM | #2 |
Rep 224
The wheels will physically bolt on. I’ll defer to others about the desired offsets of wider wheels because I haven’t looked into it myself on this platform.
Your 1% question is both, really. Overall tire diameter affects speedo and odometer accuracy and 1% difference front to rear affects awd and traction control function. With those wheel widths I’d go with 255/45 and 285/40, or 265/45 and 295/40. |
04detroitls64.00 |
02-27-2024, 09:11 AM | #3 |
Rep 1,000
Yes those should fit no problem. Up front I would want a 12-15mm spacer though to be flush with the rears. They will likely clear the brakes and suspension without but the front will be sunken in more than the rear.
For tires, 255/45/20 and 295/40/20 is a good fit.
04detroitls64.00 pdotc8412.00 |
03-03-2024, 12:29 PM | #4 |
Rep 92
Drives: 21 x3m
Bump for question about m3 wheels
I know almost nothing about wheel fitment, but found a nice set of HREs locally (et 8 &10 iirc) will these ift? |
