      02-18-2024, 10:16 PM   #1
Tweaksta
Drives: 2011 BMW X3 F25 30d M Sport
Question about sunroof/moonroof drain hole blocking issue
Can anyone explain the correlation between blocked drain holes in the sunroof and water dripping into the footwell?
The sunroof itself isn't leaking at all and the headliner is bone dry but the common consensus is that the drain holes are clogged up.
What is the connection?
If the water is collecting in the gutter around the sunroof track then how is it dripping onto the carpet below the glove box?
