12-27-2023, 09:27 PM | #1 |
Rep 24
Transfer case issue, disconnect fuse
I just replaced the front differential on my f25 x3 xDrive 28i with a used one. The old one had cracked due to a pothole hit.
After replacing, I noticed that the car shudders while pulling away (1st to 2nd), also makes a droning sound. Once up to speed the sound goes away. Also, the car is little hesitant while going up an incline. I removed fuse 37 (4x4) under the glove box and all problems disappeared except for a driving stabilization warning on the dash. No ABS or Airbag light. Don't know if it's a bad front differential or the transfer case going bad. Have had the fluids replaced on both of them. The replacement was done at a independent workshop. May be the front differential was not properly installed? Is it okay to drive the car with the xDrive fused pulled? Am I going to further damage other parts on the car driving like this? |
12-29-2023, 03:26 PM | #3 |
Rep 505
Drives: 2009 E93 M3 DCT
Take it back to the shop who did the work. Why try to diagnose it your self?
12-29-2023, 05:12 PM | #4 |
Rep 292
01-01-2024, 08:10 PM | #5 | |
Rep 24
Car runs fine with the fuse disconnected, no shuddering or clunks, just a "Driving Stabilization warning/DSC" on the dash and can't change between NORMAL/SPORTS/SPORTS+ modes. There are no ABS/Airbag warnings. |
03-08-2024, 05:47 PM | #6 |
Rep 1
I recently did this a few days ago. It's driving so much smoother now. I know my transfer case must be going out. Already changed the fluid and calibrated it at my indy shop, but the shuddering is still there. Pulled the fuse and it feels normal now. How has the pulled fuse been treating you, everything ok? From what I've been reading, it shouldn't damage anything, but I'd like some real world advice.
03-09-2024, 09:48 AM | #7 | |
Rep 24
Going to order a rebuild kit to repair the transfer case soon. |
