      03-08-2023, 08:47 PM   #1
A340600driver
A340600driver's Avatar
Drives: BMW f31/f25/e85
bmw oil level sensor fault
Looking for some help , I have a oil level inactive message on my idrive screen coupled with low oil temp after driving for quite some time . The oil temp gauge barely moves from a 1/4 and oil level is unavailable . We slaved a new one in but just plugged it in did not remove old one from oil tank and we still had the same fault . We plugged the old one back in and reset everything and it seemed to work , however same symptoms have occurred . ISTA say oil conditioning sensor / waterpump/ alternator if I remember correctly . Cannot reset oil service neither . Car runs fine otherwise . Suspect the oil level sensor is at fault ? Any thoughts ? Will probably change the sensor tomorrow , just wondering if anyone has had the same issue. Sorry if I’m not too clear .
      03-09-2023, 01:59 PM   #2
A340600driver
Changed sensor nil fix , suspect water pump as it runs slightly when I shut off car . Any other thoughts ? Thanks
