      11-01-2021, 09:28 AM   #1
vrCavu
Drives: '15 x3 28d
EGR Valve issues
Morning all,
I pulled and cleaned my EGR valve from our '15 F25 this weekend. It wasn't terribly dirty or clogged but it was physically sticking. After cleaning it very well it seemed fine with no sticking issues. I'm receiving 3 fault codes this morning. (It's also very cold out) Valve closed too loosely, mechanically faulty near closed and mechanically faulty near open.
I've read a lot on here regarding the recall on the EGR cooler, I would like to avoid any other issues with that. Seems like a stuck open valve can do some damage. Should I replace the valve or reset the adaptations and fault codes and see if that solves it? I have not done the adaptation reset before and am a bit unclear on that process with ISTA.
Thank you
      11-01-2021, 12:35 PM   #2
andreigbs
Dr Drei
Drives: X3d
'16 X3d  [0.00]
You should probably post this in the N47/B47 diesel subforums. That's where all the dieselheads are...
GLK 250 // 126xxx miles // 36 MPG // Mobil1 ESP 5w30
      11-01-2021, 02:52 PM   #3
vrCavu
Drives: '15 x3 28d
ok, will post there. TY
      11-01-2021, 07:16 PM   #4
vrCavu
Drives: '15 x3 28d
https://f30.bimmerpost.com/forums/sh....php?t=1871207
