04-11-2021, 08:36 AM | #1 |
Rep 18
Help, was i sold wrong part (injectors)?? HELP
1st post, so bear with me pls. Morning everyone, need professional input PLEASE. About a month ago, I've decided to replace plugs, coils and injectors (2013 F25 N20).
1. Plugs are NGK, made sure they're gapped and torqued to spec. (purchased these in the past for same vehicle with no issues) 2. Coils are Delphi (purchased these in the past for same vehicle with no issues) 3. Injectors. I reached out to a reputable seller online with my VIN# and asked what injectors i need for my 2013 N20. They replied with a direct link to the part and i purchased a set of 4, which also came with decouplers. After installation, the problem started. The car is shaking/rough idling. Most of the time it will only jerk when in "Drive" and NOT when in P. As the weather started warming up, i feel like it started doing it more. I've been trying to figure this out for a month now and needles to say, driving experience SUCKS as the whole car shakes every time i stop at the light. Checked all hoses to make sure there is no vacuum leak, checked all plugs, reseated coils etc... HERE's my question. I went back to my order and see that the injectors i purchased are for SULEV vehicles ie N26 engines. I know some components are same for SULEV and non-SULEV vehicles, but not sure about the injectors. Could THAT be my issue? The number (0261500153) is the same on new and old injectors, but not sure if that's necessarily a part number that i should be looking at. Silly me, threw out old injectors, so I cannot install them back as a test (lesson learned)... Additional info: I did adjust injector values and reset adaptations with ISTA EU5 injectors CAN SULEV RATED INJECTORS BE USED ON A NON-SULEV VEHICLE? Thank you all in advance! |
04-11-2021, 09:46 AM | #2 |
Just one more taste...
566
Rep 2,011
Your best bet would be to check your VIN at RealOEM and see if the part numbers match up.
Or did you try FCPEuro? They have a very comprehensive and accurate website for parts Edit: just checked the PN you listed and it appears to be N26 specific https://www.realoem.com/bmw/enUS/partxref?q=13647629174 These appear to be the injectors you need: https://www.fcpeuro.com/products/bmw...ch-13647639994 https://www.realoem.com/bmw/enUS/par...397&series=F25
My Build Thread: Jet Black 6MT 128i with MSport
Mendo20193.00 |
04-11-2021, 10:07 AM | #3 |
Rep 18
Yeah.. I'm afraid that's where i purchased the "wrong injectors", but wasn't going to throw names around until i'm sure that is my problem first...
Looking at RealOEM, it lists EU5 & EU6. My VIN is 0A25833 if that helps. Also, picture attached of original injector. Any assistance to pointing me to the correct injectors is greatly appreciated. Thanks |
04-11-2021, 10:10 AM | #4 | |
Rep 18
both below are showing as compatible, although are different types: https://www.fcpeuro.com/products/bmw...70-13647597871 https://www.fcpeuro.com/products/bmw...ch-13647639994 Last edited by Mendo2019; 04-11-2021 at 10:15 AM.. Reason: EDIT: |
04-11-2021, 10:39 AM | #5 |
Check out my Youtube @n55david!
1305
Rep 3,554
Drives: 2017 m240i, 2015 X3 x35i
regardless If they are wrong or right.. did you code the new ones into the dme?
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
04-11-2021, 10:50 AM | #6 |
566
Rep 2,011
Based on your vin, it looks like you had a 10/12 prod date so the EU5 are the correct ones.
https://www.fcpeuro.com/products/bmw...70-13647597871 https://www.realoem.com/bmw/enUS/sho...diagId=13_1416
04-11-2021, 10:58 AM | #7 |
Rep 18
04-11-2021, 11:05 AM | #8 | |
Rep 18
Are we in agreement that the car shaking CAN be caused by this mix-up? I know it's a long shot as not many people may have experienced this exact issue, but wondering if anyone has similar experience. Thank you all. |
04-12-2021, 03:49 AM | #9 |
Rep 615
Second that. Even the most reputable parts sellers like FCP will tell you to perform the procedure on ISTA to verify compatibility. Having the VIN is not enough when doing injectors.
Tags |
2013, eu5, f25, injectors, n20, x3 28i |
