      03-13-2021, 01:41 PM   #1
hajar
Drives: BMW X3 F25
Code min temperature warning
Does anyone by any chance know how to code min temperature warning using BimmerCode (expert mode)?
      03-13-2021, 02:25 PM   #2
pungo
pungo's Avatar
977
Drives: Z4MC, X3-35i,525i, Corrado G60
AFAIK, on this model it can't be completely disabled, but I could be wrong. I've disabled it on several other other models. I believe it can be disable so if it's 37F of less when you start the vehicle, it won't chime, but if the temp drops to 37 while driving, you get the chime. So for me it's above 37 in my garage, and when I start driving the outside temp is 37 or less and it chimes
KOMBI>CC_TEMPERATURWARNUNG=nicht aktiv
      03-13-2021, 02:31 PM   #3
hajar
Drives: BMW X3 F25
Thanks. So if I want the chime I should set it to aktiv if I don't then I set it to nicht aktiv, right? And its only this setting, no other setting should be changed in parallel?
