10-19-2020, 11:31 AM | #1 |
Rep 15
Steering Response. Drive Moderately. No Power Steering after Cranking Car
After cranking my car, I would say more than half of the time over the past few weeks, I have gotten the BMW warning stating: Steering Response. Drive Moderately. It leaves me with no Power Steering and I must either hit "Ok" to the warning on the idrive screen to gain power steering, or if that doesn't work put the car in drive or reverse to gain Power Steering. Sometimes neither works but usually after at most I'd say 25-30 secs the wheel breaks free and I gain Power Steering and the ability to drive the car. Thinking Steering Angle Sensor, but need help pinpointing the cause. I have seen walkthroughs for resetting the DSC, but I tried it to no success. Have not seen many threads regarding this except for BMW replacing a lot of steering racks and that is out of the equation atm. Thanks! Any advice appreciated.
10-19-2020, 06:28 PM | #3 |
Rep 2,564
You need to read the error codes with a good scanner like e-sys, it could be a number of things and the error codes will help narrow it down. As alpineweissF25 mentioned the battery, make sure it's healthy before attempting any further diagnostics.
10-21-2020, 10:08 PM | #5 |
Rep 15
I have read the codes and was getting a steering angle sensor fault every time. I believe that is what it said along with several other DSC codes. Ill have to read it again tomorrow and repost. Thanks pungo.
10-31-2020, 08:31 PM | #7 |
Rep 2,564
The newness of the battery doesn't mean it's healthy. The battery heath needs to be verified before attempting to diagnose error codes since a unhealthy battery can throw false errors.
If the battery is healthy, use ista+ to diagnose per the test plans. |
Polo088161616.00 |
01-20-2021, 01:45 PM | #8 |
Rep 15
Revisiting my original post. I had a local shop test the battery and from the terminals the reader said good battery, but shop owner said the CCA’s were a little low and that the steering could possibly just be pulling a strong load. Any suggestions?
01-21-2021, 07:48 PM | #9 | |
Rep 32
This may not be the best route but its the most efficient route in my opinion. When you have electrical issues, the first thing is to positively ensure it isn't a battery issue because most cases it is. It's also the easiest and cheapest route to go before you really have to deep dive with diagnosing issues. Swap battery with the same OEM spec, registered it, and see if it goes away. |
01-28-2021, 08:02 PM | #11 |
Rep 15
New battery in and registered. Same steering wheel alert on the dash... any ideas on next steps? Looks like I’ll be downloading ista for easier troubleshooting
01-28-2021, 09:15 PM | #12 |
Rep 2,564
You're on the right path with ista+, not sure why you didn't do that a few months ago when 1st recommended Anyway, hopefully ista will help pinpoint the issue.
01-28-2021, 09:57 PM | #13 |
Rep 1,912
Following thread: had the steering errors couple times but sensed no change in actual steering effort, until today. But car oddly self-corrected while driving. At home ignition off then back on, iDrive messages gone. cruise control faulted same time as steering; it self-corrected also.
Check codes tomorrow. |
01-29-2021, 10:36 AM | #14 |
Rep 15
Shop owner told me he’s never had someone “almost” have to get their rack replaced and then said oh no it’s this sensor. Does ista+ give better diagnosis info than bimmerlink? I heard the codes are totally different for bimmerlink and do not translate in a google search of the code
01-29-2021, 12:05 PM | #15 |
Rep 1,912
OP: are you able to clear any or all the fault codes with BimmerLink?
Which if the 3 memory categories in BimmerLink are your codes pulled from? thanks/Bill |
01-29-2021, 05:17 PM | #16 | |
Rep 2,564
02-03-2021, 02:17 PM | #17 | |
Rep 32
Once those steps are done, I would read codes again using ISTA. This will give you current and updated fault codes, if there is any. Those codes will then give you a general direction on what to do next. |
02-04-2021, 02:02 PM | #18 |
Rep 15
Bimmerlink will clear fault codes. Sometimes there will be 1 or 2 it is unable to clear however. Not sure what the memory categories are. I recall permanent category and 1 or 2 others, but that may not be what you’re referring to
02-04-2021, 02:06 PM | #19 | |
Rep 15
02-04-2021, 02:07 PM | #20 | |
Rep 15
