      08-31-2020, 07:30 PM   #1
Nikful
Drives: 2017 BMW X3 XDrive 28i
Does anyone know if 7 1/2 X 17 2014 X1 wheels will work on my 2017 X3 x28i? We drive gravel roads and would like a taller side wall. Currently running 245/45-19.
I did more digging and found that X1s use a 12mm stud and X3s use a 14mm stud. The X1 wheel set on Craigslist for $190 was a good deal . Oh well.
      09-01-2020, 04:25 PM   #2
najnad
General of the Space Forces
najnad's Avatar
Drives: 11 X3 35i M-sport
just go with 18" X3 wheels. Not sure 17" will clear the calipers.
      09-01-2020, 05:14 PM   #3
Barbera335
Drives: F25
I have 17 inch wheels on my X3. Tire size is 245/55R17. Clear the calipers just fine.
      09-02-2020, 12:41 AM   #4
6MT_Addict
6MT_Addict's Avatar
Drives: 08 135i M Sport 6MT, 15 X3 35i
2008 BMW 135i  [10.00]
17" clears the calipers unless you have the upsized sport package brakes.
I learned the hard way that 18" is the minimum size for those...
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport
Full 3M Vinyl Wrap | Flat Black Grilles
      09-02-2020, 12:43 AM   #5
6MT_Addict
6MT_Addict's Avatar
Lug bolts will still likely work. I have E90 (2007-12 3 series) Style 162 18x8 wheels on all 4 corners for my winter setup and the 14mm bolts thread fine.
You need to use a wheel offset calculator and figure out if the offset of the X1 wheel is within spec for the F25.
      09-03-2020, 04:34 PM   #6
Nikful
Size:  423.9 KBThe X1 17" wheels fit perfectly and I bought them for $40 each. Just had Discount Tire mount new Falken Wildpeak A/T Trail 235/60-17 tires.
