10-30-2019, 10:34 AM | #1 |
Rep 12
Angel eyes (led drl) problem
Dear guys , one ring of the "angel eyes" is losing intensity day by day and moreover is changing color from white to yellow (look attached photo to understand what I am speaking about). Consulting bmw electronic parts catalogue I noticed that, unlike previous versions of x3 and other bmw cars, there is no replacement for the drl's LEDs.
Does anyone know if the lighting is integrated into the lighthouse or if there is a method to change it? Thank you for your help. My car is a x3 f25 facelift. |
10-30-2019, 03:45 PM | #2 |
Rep 1,913
My guess is the box is sealed; I have heard of people with much older Bimmers heating the enclosure in oven to loosen/remove and replace lenses- and some cut the enclosure open to add halo rings as a DIY upgrade.
Best bet may be to replace entire unit- perhaps source from EBay or salvage place. Good luck Bill |
10-31-2019, 04:07 AM | #3 | |
Rep 12
I think it's unbeliveable I have to change the whole headlight for a single led failure. I am so disappointed about this BMW choice. |
10-31-2019, 06:27 AM | #4 |
Rep 1,913
I looked at repair instructions at NewTis.info site and could not find any info about the angel eye halo rings. You might take a look, maybe I missed something but I think not.
10-31-2019, 07:15 AM | #5 |
Rep 12
I looked yesterday on that site but there is no document about the F25 LCI drl repair... When I Press "change drl led" the site redirect me to the document related to older f25 (not LCI).
10-31-2019, 09:47 AM | #6 |
Rep 11,857
Drives: MY24 G01 AW Msport
ask one of the vendors at getbmwparts.com
it might be light module thats going bad. |
10-31-2019, 10:39 AM | #7 |
Rep 470
Angel eye LEDs are replaceable, but they are installed on the bottom of the headlight.
https://www.fcpeuro.com/products/bmw...263051#fitment
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280' |
nyalpine907444.00 |
10-31-2019, 11:35 AM | #8 | |
Rep 12
In the lower part of the headlight Is only installed the Xenon control unit |
10-31-2019, 11:43 AM | #9 |
Rep 11,857
what year is your X3?
10-31-2019, 04:33 PM | #11 |
Rep 470
I don't know that I'd trust that diagram. I've seen plenty of errors in them before. Only real way to know is pop off the front bumper and see.
Current mods
nyalpine907444.00 |
10-31-2019, 09:31 PM | #12 |
Rep 11,857
The problem is that diagram is not for your 2014 x3
You need item 15, module thats is located at bottom of headlamp. doodlebro is correct https://www.getbmwparts.com/v-2014-b...amp-components |
10-31-2019, 11:19 PM | #13 | |
Rep 21
Pelicanparts fitment for this item is up to 03/2014 https://www.pelicanparts.com/More_In...-7-263-051-BOE |
11-01-2019, 03:23 AM | #14 | |
Rep 12
11-01-2019, 04:44 AM | #15 |
Rep 11,857
The correct light is at bottom of the link, with same part you are showing that matches oem part number
11-01-2019, 06:02 AM | #16 |
Rep 12
11-01-2019, 06:28 AM | #17 |
Rep 11,857
11-01-2019, 10:06 AM | #18 |
Rep 470
I re-iterate, this is why realOEM can be so confusing.
OP, you have to remove the bumper and see what light you have.
Current mods
03-02-2020, 04:08 PM | #20 |
Rep 12
03-02-2020, 06:19 PM | #21 |
Rep 2,599
11-30-2020, 12:29 PM | #22 |
Rep 1
Same model same issue
I am having the same issue, one of the angel lights has turned yellow. BMW suggesting a $1600 module replacement. Thought to check before here before I go ahead and do that. what did you finally do?
Tags |
angel eye, bmw, drl, f25 lci |
