10-22-2019, 02:36 PM | #1 |
Rep 38
Hello,
I took my car to dealership to fix overheating issue, they replaced the water pump. But after i took the car , I was driving like normal and on red light i changed to mode to Sports and gave acceleration, All of a sudden , i got a drive train malfunction light followed by engine light. Whenever i start my car , it shows me rough idle , RPM going up n down for a minute. Or whenever i try to give accelerator a little tight. I check to other nearby mechanic , he found some MAS codes , he reset them and still after sometime engine light came in. I just found under hood. This big black hose which is opened. What is this hose ? Is that the cause of the issue ? Can i fix it by myself or have to take it to mechanic again? Picture attached |
10-22-2019, 03:44 PM | #2 |
Rep 221
That is indeed your problem. Check to see if it is cracked, they are notorious for failing. If not then grab it and push it into position over the metal inlet until you here the metal clip click into place.
2011 F25 X3 35i |M-Sport Front Bumper Conversion|Largus Full Adjustable Coilovers|FTP Charge Pipes|Gutted Catalytic Downpipe|RB Oil Cooler Thermostat Delete|25 Row Oil Cooler|Custom Built Cold Air Intake|9"AEM Cone Filter Behind Kidney Grills With Outerwear|Precision Raceworks Coils|BM3 Stage 2 E30 Tune| BM3 Upgraded 8-speed TCU Flash|395mm X5M Front Brakes
supreetsingh5.00 |
10-22-2019, 03:52 PM | #3 |
Rep 38
Had it done any damage to my engine ? I hardly drive it for 100km in 3 days since i pick it up from workshop. I am thinking to take it to them and show them why they left it open
10-22-2019, 04:13 PM | #4 |
Rep 221
Nah you shouldn't have any problems.
supreetsingh5.00 |
10-22-2019, 04:50 PM | #5 |
Rep 1,912
Looks like the mechanic who cleared the mass air fault codes did not inspect the car; if he would have looked he should have spotted that loose air intake hose and corrected the leak, then the codes would not have re-appeared. Or maybe the hose cane loose after you left the shop?
supreetsingh5.00 |
10-22-2019, 07:40 PM | #6 | |
Rep 38
10-23-2019, 08:39 AM | #7 |
General of the Space Forces
171
Rep 723
Let the dealership's maintenance manager know they left the charge pipe disconnected from the throttle body. They probably dont care, but if they do they might offer you something for your trouble.
Wgosma810.50 |
