      10-04-2019, 06:01 PM   #1
sbabcock23
Drives: '17 X3
F25 - Retrofit Rear Window Sunshade?
Hi Everyone,
When I ordered my '17 X3 I did not order the rear window shades/sun shades and now I am regretting it. Does anyone know either the parts or effort required to added the built in sunshade to the rear doors or a good third part alternative?
Thanks!
      10-04-2019, 06:56 PM   #2
richardodn
Drives: '12 X3 35iX/'20 440ix cabrio
The door panels themselves are different. MSRP is about $1300 each for leather interiors; assuming they're still available. (Some are. Some aren't.) The shades are about $290 each. I believe the parts are the same for all years so you may be able to find used donors. Effort shouldn't be much more than removing the old door panels and installing new.
      10-04-2019, 09:24 PM   #3
WagonR
Drives: 2017 M2
There's also the window trim that needs to be replaced. The window trim for the shades has the clips that the shades connect to when you pull them up. The used route is probably the only economical way to add the rear shades. If you're buying parts new, it may be cheaper to just sell the current car and buy one with the rear shades.
Current:
2017 F87 M2 6MT
2013 F25 X3 3.5i
2008 E90 M3 6MT
      10-05-2019, 10:27 AM   #4
pungo
pungo's Avatar
If you want the sunshade for blocking the sun/heat, I would just use a quality ceramic window film. These new films have a high Total Solar Energy Rejected (TSER) %. It is amazing how much heat they reject without needing to go with a dark limo tint, some are nearly clear.
      10-05-2019, 11:54 AM   #5
sbabcock23
Drives: '17 X3
Thanks for the feedback. Has anyone used the magnetic snap in shades?
      10-09-2019, 05:53 PM   #6
scostu
scostu's Avatar
Drives: 2016 F25
I did on my previous F31. They worked...….so long as my little 2 monsters didn't grab them and use them as faceshields!
Tags
rear, retrofix, shade, sunshade
