      01-14-2019, 04:11 PM   #1
Sab0matik
Drives: 2014 X3 28i
2014 X3 Bluetooth issue
I'm looking for some guidance as I am the new owner of a used BMW X3 28i and I am currently having Bluetooth issues. I have read through several posts regarding this issue, but mine is slightly different and was hoping those more experienced could advise.
Features: No NAV or Tech pkg
Bluetooth telephone works perfect
I picked up the BMW Y cable and my phone connects and plays.. only thing is it only plays on the left side speakers. Any advise would be appreciated! I have made some progress but would like full audio via Bluetooth. Thanks in advance
Sab
      01-15-2019, 06:42 AM   #2
Riick
What phone are you using?
      01-15-2019, 06:49 AM   #3
Sab0matik
Drives: 2014 X3 28i
I have an iPhone 7+ and have tried an iPhone 7 and a 10 with the same issue
      01-15-2019, 08:18 AM   #4
Barbera335
Drives: F25
Sounds like a problem with your Y cable. I would try another cable
      01-15-2019, 08:22 AM   #5
Riick
Bluetooth is wireless, no cables required.
      01-15-2019, 09:40 AM   #6
pokerface
pokerface's Avatar
Drives: F25 X3 N20 / F80 ZCP
agreed.. Y Cable is for music (ipods)
      01-15-2019, 11:26 AM   #7
Sab0matik
Drives: 2014 X3 28i
Thanks for the replies.. I forgot to mention that we tried several different BMW Y cables and the same issue occurred. I also purchased a cheap Bluetooth/Aux connection and the speakers on the left side still only function. I understand the cables should play music, and they do work. I just want all the speakers to play.
*The radio plays all with no issue*
Is there a module I can reset or a reset method to get all speakers online with the Bluetooth/AUX? TIA
      01-15-2019, 12:18 PM   #8
pokerface
pokerface's Avatar
stupid question - are there Left/Right balance controls on your phone and in the car that you could set?
Is there potentially an issue with the Aux In outlet itself that is stopping the Right side audio?
      01-15-2019, 12:31 PM   #9
Sab0matik
Drives: 2014 X3 28i
There are no left/right controls on the phone but the car is centered out. When adjusted to the right, no audio plays but only while using the AUX/BT.. 🤷🏻*♂️
      01-15-2019, 03:49 PM   #10
Riick
Okay we need to get something straight here. Bluetooth is wireless and no cable is required. So why are you using a cable?
      01-15-2019, 03:55 PM   #11
Sab0matik
Drives: 2014 X3 28i
The cable is needed to connect and play audio as I do not have the package that plays strictly through Bluetooth. This cable allows the device to be found but only plays on one side of the car.
      01-15-2019, 06:33 PM   #12
Riick
https://www.amazon.com/Kinivo-BTC450...r+adapter+aptx
Call it done.
      01-15-2019, 08:41 PM   #13
Sab0matik
Drives: 2014 X3 28i
I have already purchased something similar and audio only emits from the left side speakers in the vehicle. Buying another unit will not fix this issue I don't believe. Any troubleshooting I could perform or resetting of the system to test aux/BT functionality through all speakers?
      01-16-2019, 06:38 AM   #14
Riick
Replace the AUX/USB plug on the vehicle. They're cheap. People break them all the time.
https://www.fcpeuro.com/products/bmw...xoCwQoQAvD_BwE
      01-16-2019, 09:09 AM   #15
nyalpine90
nyalpine90's Avatar
7444
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
when your phone is plugged in, check the settings on the idrive "TONE"
      01-16-2019, 10:58 AM   #16
Sab0matik
Drives: 2014 X3 28i
I verified the tone settings when the phone is connected and they are all centered out. If I slide them to the right, the audio stops but the left works. To me it sounds like it may be something with the connections like Riick mentioned but I'm not sure.
      01-16-2019, 11:41 AM   #17
nyalpine90
nyalpine90's Avatar
7444
2016 BMW X4  [9.33]
try a different device/phone
      01-16-2019, 02:56 PM   #18
Riick
Replace the AUX/USB port. They break all the time when people forget they're plugged in. Takes 30 seconds.
