12-13-2018, 06:28 PM | #1 |
Rep 254
Oil catch can?
Just checking in to see if anyone has installed an oil catch can for your F25 and if so, have you been finding much oil in there? I have a 35i that is running higher boost via Dinantronics Stage 1 so I'm looking to see if it would be worthwhile to have. I just cleaned my MAF sensor which I suppose is rather easy as things go but if adding a catch can eliminates the need for doing that and also reduces deposits on the intake tract + valves perhaps it is worth adding. Catch cans look fairly easy to install and aren't particularly expensive (<$200). The biggest downside I see is that they are only for race applications which in Californese means it'll fail visual smog inspection.
12-13-2018, 06:58 PM | #2 |
Rep 383
"Search" this forum is your best friend
Oil Catch Can https://x3.xbimmers.com/forums/showthread.php?t=1530117 Hope this helps |
12-15-2018, 10:58 AM | #3 |
Rep 254
Oh snap I think that was the thread that got me thinking about the catch can originally. However, I haven't seen whether or not anyone has seen significant oil accumulation on the F25 N55. In any case I'll go ask it on that thread.
