06-25-2018, 03:12 AM | #1 |
Rep 64
Transfer case assembly part number
So turns out I need a new transfer case. Realoem shows three different numbers. I know it has "ATC 45L" stamped on it but which of the three numbers should I look for?
It's for a 2012 X3 35i xdrive |
06-25-2018, 07:59 AM | #2 |
Rep 660
You want the AT one as that is the remanufactured part. The first number is listed as 'ended' which means it is no longer available and the second number is for a new part.
06-29-2018, 04:18 AM | #3 |
Rep 64
Would you know if the 27108697255 comes with or without the actuator motor? If it doesn't, can I just transfer over my old one onto the new one without hassle/programming?
