15.5KVIEWS
17REPLIES
1APPRECIATES
12ACTIVE PEOPLE
02-12-2019LAST POST
04-29-2018
04-29-2018
vestaviascott user avatar
vestaviascott
9 REP
Anyone have any experience with these?
http://www.carnaviplayer.com/bmw-x3f25x4f26-2011-2017-aftermarket-navigation-system-p-1155
$560 shipped with Carplay module. Basically plug and play replacement of existing nav screen. Touch screen enabled and still use your existing idrive controller and apps.
04-30-2018
vestaviascott
9 REP
More info:
Aftermarket GPS Navigation Head Unit is specially designed to upgrade BMW X3(F25)/X4(F26) 2010-2017 factory LCD screen unit and add a DVD player(optional). It has the same plug and harness as factory head unit, totally plug and play. This head unit only replaces the original LCD screen unit and retains the factory FM/CD unit, so the original BMW car computer/CD/FM/AM/Sirius/XM will still work as before.
Vehicles Supported:
BMW X3(F25) 2010, 2011, 2012, 2013, 2014, 2015, 2016, 2017
BMW X4(F26) 2014, 2015, 2016, 2017, 2018
05-02-2018
Duckles McGee user avatar
Duckles McGee
17 REP
I’m interested as well.
05-02-2018
Merlin82 user avatar
Merlin82
49 REP
Ive been tossing around the idea of one of these for a while.
05-02-2018
64-bit user avatar
64-bit
323 REP
1.1K POSTS
Any review yet?
05-06-2018
x3sm user avatar
x3sm
396 REP
group by?
05-07-2018
najnad user avatar
najnad
General of the Space Forces
191 REP
does it work with OEM heads up display and OEM cameras? And displays all vehicle info?
05-09-2018
Duckles McGee
17 REP
12-14-2018
ornithology user avatar
ornithology
6 REP
Subscribed...
12-14-2018
Riick user avatar
Riick
143 REP
Ah yes, another made in China display.
These don't work.
12-14-2018
Ylinen user avatar
Ylinen
12 REP
I went with the AVIN USA model because I wanted Android 7.1 and more RAM. Love it. Best thing I did for my X3. Wish BMW would use it.
Have all the I-Drive stuff and now a full Android unit as well.
It is cheaper than the unit you list.
https://avinusa.com/
12-14-2018
x3sm user avatar
x3sm
396 REP
Hows the navigation on it? I heard good things about AVIN.
12-16-2018
MetaX user avatar
MetaX
122 REP
I'd like to know if you need to use the AUX port in the arm rest to get audio on the F25. I saw BMW DIY Guy's install and review videos wherein he says that most BMWs need you to run the audio out from the AVIN to the AUX in port in the arm rest to get audio. Evidently, some do not require that connection where audio is natively sent to the head unit.
12-17-2018
x3sm user avatar
x3sm
396 REP
AVIN requires you to hook it up to cars AUX, if you look at their website they have an option when you "build" your AVIN system to include a split cable for AUX.
Appreciate1
12-31-2018
12-31-2018
Ylinen user avatar
Ylinen
12 REP
I use Waze for navigation. I also installed HeadUnit Emulator from the play store so if I want; I can have android Auto also. I do not use the aux port in the arm rest. Just connected the included wiring harness and moved the fiber optic cables. Get either the car i-drive audio and the android unit audio at the same time if I want. e.g. Radio and then waze announcements.
This is the best upgrade I have done for my X3. Get all the I-Drive BMW stuff and now I get an Android computer too. GREAT.
01-06-2019
najnad user avatar
najnad
191 REP
if there was a way to get the HUD to use the new android apps, I would jump on this.
01-06-2019
MLHH1234 user avatar
MLHH1234
6 REP
AVIN USA really need to develop a front facing camera to work with these units that will emulate the BMW night vision/pedestrian detection feature. Even if they retailed at hundreds of £/$, they would sell by the shed load :)
02-12-2019
thatg user avatar
thatg
150 REP
1.3K POSTS
any threads where someone bit the bullet and installed? I had one of these on my e46 m3, it was ok, screen wouldnt get bright enough and i had an issue with bluetooth skipping. was a couple years ago and the OS would skip around, not as smooth as oem. I see a ton of cheap ones on ebay.
https://www.ebay.com/sch/i.html?_from=R40&_nkw=bmw+x3+android+f25&_sacat=0&LH_TitleDesc=0&LH_TitleDesc=0&_sop=15
