      10-24-2017, 03:18 PM   #1
Maina
Drives: x3 35i
4.25 psi or higher boost BMS Stage 1
Has anyone on here increased the boost of the BMS Stage 1 in the x3 n55? Any problems that this might have caused? Currently I am running on 3.5 psi over stock + e30 mix and the sav drives well, but won't mind a little more torque running 4.25 psi (or more ) boost on e35 mix. I will only use 93 octane in the winter.
Current - 2011 x3 35i/BMS Stage 1
Previous - 2008 Montego Blue 135i/M-sport /BMS-DCI/Cobb stage1 aggressive /235s Potenza s04 Pole Position - 265s Potenza RE11 /ATE TYP 200/EBC Yellow Stuff/NGK 5992s/Slotted and drilled rotors
      10-24-2017, 03:56 PM   #2
airbagit13
Drives: 2018 BMW x3
Curious of this as well as I am hovering over the buy it now button for the BMS Stage 1. I also only have a 28i so not sure if it's worth even getting but I wouldn't mind the extra bit of Horsepower.
      10-30-2017, 08:44 PM   #3
Maina
Drives: x3 35i
Isn't anybody modifying their cars in this forum? I figured there would be at least ten people commenting by now its old platform after all.
      10-31-2017, 06:34 AM   #4
ina93
Isa Ali
ina93's Avatar
Trinidad_and_tobago
12
Drives: 2012 X3 35i
If you’re looking for some more power why not consider getting an ECU flash? It’ll probably be noticeably stronger than the BMS piggyback.
      11-01-2017, 09:50 PM   #5
Maina
Drives: x3 35i
Why would an ECU flash be stronger then a piggyback? It all comes down to how much the boost is raised one way or another, no? The n54 I know for a fact has similar power gains by Cobb and JB4 on certain maps.
      11-09-2017, 08:30 PM   #6
Maina
Drives: x3 35i
Quick update on the tread, I saw that there has been some interest. After a thorough search trough the forums and contacting BMS directly, I have came to the conclusion that I shot myself in the leg. The new version of the BMS Stage 1 is not adjustable for higher boost even with the extra cable and it is unsafe doing so on the Stage 1 anyway. If you want more boost than the 12.5 psi with Stage 1 only option is going to JB4. They are compatible with the x3, only some function won't work that is why JB4 is not advertised for the x3. I really waned to mix e85 with 93 for extra power, but that is only effective with JB4. Doing it on Stage 1 does not deliver any additional power over 93 gas and the gas mileage gets really poor.
