      02-19-2017, 06:32 PM   #1
MooreOfDerek
Drives: 08' BMW 335xi 6AT
F25(N52) Engine Whining Idle & Running - Crankcase?
Hello,
Recently got a 2011 X3. Drove about 500 miles and now it has a whining sound when the car is idling \ running
The research I have found so far is that the sound is cased by the Crankcase Ventilation valve or the breather.
A good amount of suction occurs when the car is idling and I undo the oil cap. So this is definitely the case from what all i have collected.
Anyone have any ideas as to what all to check to try and isolate which part of the CCV system it could be before I drop 375$ on a new breather?
Thanks,
Derek
      02-19-2017, 11:55 PM   #2
Radioactive
Drives: '11 X3 28i '10 535i '04 325i
This happen to me last year. Something similar. Haven't had problem since.
http://x3.xbimmers.com/forums/showthread.php?t=1241091
A cheap fix maybe found in this forum. Diaphragm replacement(?) (Didn't read whole forum!)
http://www.bimmerfest.com/forums/sho...d.php?t=825981
Worth a shot maybe if it doesn't go away
Tags
2011, ccv, f25, n52, whine
