      05-20-2016, 09:35 PM   #1
pat_03
Drives: 2012 X3 35i
F25 X3 Overheating Warning Message
Hey all. I have a 2012 X3 35i and the other day I had an I drive warning about the car overheating and to drive cautiously, or something like that. It wouldn't let me accelerate and when I pulled over I got a different error stating the car had overheated. I got out, nothing was hot or steaming and the temp Guage was normal so I don't think it actually overheated. I haven't seen the error since but now the fan seems to come on full speed and then turn off and it does this frequently. Thoughts on what the culprit is?
      05-21-2016, 05:12 AM   #2
pokerface
pokerface's Avatar
Drives: F25 X3 N20 / F80 ZCP
Thermostat / waterpump issue, perhaps?
      05-21-2016, 05:56 AM   #3
02420X3
Drives: 2011 X3 35i
Yes, Thermostat Module or Waterpump, most likely the Thermostat Module. Both have been replaced on my '11, and both were costly, $600+.
      05-21-2016, 06:17 AM   #4
pat_03
Drives: 2012 X3 35i
Yes this is what I keep reading about, though curious about the fan if it's not in fact getting hot? luckily my X3 is still under full extended warranty until 2018 so shouldn't cost me a penny!
      05-21-2016, 07:00 AM   #5
02420X3
Drives: 2011 X3 35i
It's not getting hot, but the failing module is saying that it is, so the fan runs. If they determine that it's bad then specifically ask them to inspect the water pump too. Perhaps you can convince them to replace both at the same time.
      05-25-2016, 10:25 AM   #6
sharpharp
Drives: x3
don't want to hijack your thread, but does anyone know the cost of the extended warranty in the uk?
      06-08-2016, 09:56 PM   #7
yabbadoo
Drives: 2013 X3 35i
had the same problem a few months ago on my 2013 x3 35i and had to replace the water pump.
      06-09-2016, 12:14 AM   #8
Tjalle
Drives: X4 35i
pat, note that shown temperature is for engine oil.
