05-21-2015, 06:36 PM | #1 |
Rep 24
Wiper blade: Bad blade? or arm issue?
It's hard for me to take a picture of the issue, but the driver-side blade on my '13 has a small air gap directly in the center under where the blade attaches.
This annoying leaves a 2" streak sometimes right in the sight-line. I haven't replaced the blades yet, because I'm wondering is this something I should have them adjust to fix? or is it just an issue where the blade as lost tension or something. Total newb here. Any info appreciated. |
05-21-2015, 07:27 PM | #2 | |
Macgyver
208
Rep 942
05-22-2015, 03:25 AM | #3 |
Rep 560
If it has always been like it, it could be the screen is not flat. Get a plastic or wooden rule and place it on the screen by the wiper blade and if there is a gap, you know it is not the blade. The wiper blades are easy to take off, so you could always place the blade against a flat surface to check that it is sitting flat.
05-22-2015, 05:46 AM | #4 |
Rep 2,073
The rear wipers of both my X3s have the gap in the centre. I reduced of the problem by flexing the outer parts of the blade. As it's the rear it's not so much of an issue. I think there are cases where arms don't exert enough pressure to flatten the blades enough.
05-23-2015, 11:19 AM | #5 | |
Rep 54
05-24-2015, 11:25 AM | #7 |
Owner
132
Rep 566
Drives: G05 30d M-Sport
actually I also have the streaks in the middle of the driver wiper, exactly as described! I tought the blades were shot (they are still the original, not aftermarkets)
Received 190911: X5 30d M-Sport:Artic Grey:Comfort Pack:Tech Pack:Visibility Pack: Driver Assist Pro Pack:Heat Pack:Glass Roof:Leather Dash
05-27-2015, 01:55 PM | #8 |
Rep 24
Drives: 2012 F25 X3 30d, 2011 E92 335i
I have the same problem, I´ve replaced the blades twice now. After replacing them the problems goes away, but after about 3 months its starts happening again, really annoying.
