12-03-2011, 12:54 PM | #1 |
Rep 11,843
Drives: MY24 G01 AW Msport
xenons on auto position question
I keep the switch on auto but i notice the lights go on during the day and its bright outside, is this normal? I check the idrive on the lighting settings i didnt find anything.. Is this a sensor error . I believe the lights go on as it gets dark lets say by 4pm it gets dark.help me out thanks
12-03-2011, 02:00 PM | #3 |
Rep 11,843
The lights go on randomly and shuts off randomly i noticed today when i made trip to store it was noon the lights were on.
12-03-2011, 03:13 PM | #4 |
Rep 60
My C class did the same. I found it particularly happened on bright winter days when the sun is low in the sky. I think it works out when lights are needed by comparing the light intensity inside and outside the car and the external sensor gets fooled when the sun is low.
Anyone with a better theory? The good news is that it never got it wrong when it was dark! |
12-03-2011, 04:58 PM | #5 |
Rep 160
It is entirely normal. I had a Mercedes too previously and the manual specifically mentioned this, but I don't think the BMW one does.
As mentioned in certain lighting conditions the sensors conclude that the lights should be on and this can be in bright sunshine and especially when it is low in the sky in winter months. |
12-03-2011, 05:14 PM | #7 |
Rep 3,855
The problem is when they don't go off again IMO. I haven't experienced it with BMW but auto headlights on my last VW came on in tunnels and then took an age to go off again despite driving in broad daylight. Assume poor algorithms were to blame. Not had a problem with the X3 though and always have lights on auto
12-03-2011, 08:38 PM | #8 |
Rep 1,876
Mine too, and I'd prefer it go along a little early instead of staying off way too long like so many folks in this area who seem to think the lights are solely for them to use in seeing the road -- not!! Much happier to have the lights on earlier to ensure other drivers and pedestrians can see us easily.
12-03-2011, 08:43 PM | #9 | |
Rep 274
12-03-2011, 09:50 PM | #10 | |
Rep 1,041
Our X3 is always garaged. If I have the auto mode selected and start the car in the garage the lights go on. There is no need for the headlights to be on to back out of the garage into sunlight. Then the lights go off. When I return to the (well-lit) garage, the headlights again go on for a few seconds and then go off when I stop the engine (again there is absolutely no need for that to occur). I never use the auto mode and just switch the lights on when I think it's appropriate. |
12-03-2011, 09:55 PM | #11 | |
Love All
170
Rep 740
12-03-2011, 10:11 PM | #12 | |
Rep 2,599
12-03-2011, 10:40 PM | #13 |
Rep 1,041
The corona rings are illuminated by a single high-intensity, air cooled and heat sunk LED at the bottom. Those have a typical life of 10,000 or more hours and turning them on and of makes no significant difference. It's just the total on-time and temperature that matters. An hour on when it's 40 deg. C outside shortens the life more than an hour on when it's 0 deg. C.
The fog lights are conventional tungsten-halogen-quartz bulbs. The they have a typical life of 900 to 1500 hours of constant burning. Cycling them does reduce the lifetime, since the initial on current rush is high and stresses the filament. The most important thing you can do with the halogen lamps is, once you turn them on, LEAVE them on for at least 2 or 3 minutes. They have a metal evaporation and re-disposition cycle that depends on the quartz envelope reaching full operating temperature. If the lamp is turned OFF too soon (less than a few minutes, some of the filament metal deposits on the inside of the envelope and never returns to the filament. Also, the deposited metal coating gradually reduces the light output. Often you can identify old halogen bulbs that have been cycled a lot by the "mirror" coating on the inside of the quartz envelope. |
12-04-2011, 02:58 AM | #14 | ||
Rep 3,855
12-04-2011, 03:21 AM | #15 | |
Rep 274
12-04-2011, 10:16 AM | #16 |
Rep 11,843
I like the auto position on the headlights so i guess its normal. The e90 xenons werent that sensitive seens like a safety feature
12-04-2011, 10:37 AM | #17 |
Rep 554
Drives: 335D MSport 2016
I always have auto light on my passat. The only problem is they come on once you go above 100mph to let everyone know you are speeding
Not that I would do that. Do they do they same in the X3? |
