08-28-2015, 03:20 AM | #1 |
Nuclear Chief of the Watch
120
Rep 637
19" wheels .... what difference do they make.
Hi OK as per the title really... I have a base X3 2.0l auto diesel.
It fantastic but if there was a cost effective upgrade I would do it. So what is the benefits of the 19" wheels? or is there other options I have missed?
BMW X3 (F25) xDrive20d SE 2017. . . . Oyster Leather . . 8 Speed Servotronic. .RFTs. . Electric Seats Canon 70D 500mm, 85mm, 40mm, 24mm Sony QX10 & GoPro Hero 3 |
08-28-2015, 05:33 AM | #3 |
120
Rep 637
17" standard P7 RFT
also have winter wheels/tyres...
08-28-2015, 05:53 AM | #4 |
Rep 5,984
Just ditching the runflats makes the most difference.
19" wheels on proper tyres ride 100x better than the 17" runflats. There is nothing to loose expect cost more to shod 19" wheels come tyre time. |
08-28-2015, 06:35 AM | #5 |
Rep 560
I like the look of 19" wheels on the X3, which is why I chose them - nothing to do with handling or practicality. The non-runflats ride so much better though!
The only other thing I didn't particularly like about my X3 was the single exhaust outlet. I had twin tail pipes fitted by BMW and I think it looks a lot nicer! |
08-28-2015, 09:02 AM | #6 |
Rep 525
I - for one - would be interested in taking a peek at that . . .
08-28-2015, 11:19 AM | #7 |
Rep 26
They Look Cooler
Better handling while cornering "on edge" as there is less sidewall to flex. Tires are more expensive. Bumps on the road will be felt more. There may be more, but that is all I can think of at the moment. |
08-30-2015, 04:02 AM | #9 |
Rep 469
I had 19" staggered 369M's with RFT- they look great on the car. Unfortunately with the semi rural roads I need to travel on with work they were too harsh. Switched to 17" to give me the tyre depth.
The 369M's are in the garage, I never got around to selling them- PM me if you're interested. |
08-30-2015, 05:06 AM | #10 |
Rep 5,984
It is the fact they are run flats rather than the fact they are 19's that make them harsh.
Hardly ant difference between 17 and 19's on the F25 for ride comfort. |
08-31-2015, 02:23 AM | #12 | |
Rep 5,984
If going from 17 run flat to 19 proper tyres there is no downsides at all, you will get a more planted drive, less fidgety on poor surfaces especially corners, and it soaks up the poorer road surfaces better too. Plus they look better of course. The only downside is cost, but even then, you can get a 19" normal tyre for hardly any more than a 17" run flat, so even the cost difference is not massive. Of course, if you wanted even more comfort, you could just whack non runflats on your 17's, but the difference between 17 and 19s for comfort is not much at all. |
08-31-2015, 05:27 AM | #13 |
Admiral
Rep 48
I have 17" non run flats (P7) and thinking about moving to 18" non run flats summer tyres.
Is this worth it? I don't want to go up to 19"! Will I get a better ride on the 18"? Less waver, less wandering in side wind ? (I can then put winters onto the 17" rims.) |
