      02-24-2018, 06:40 PM   #1
marc x
Drives: X3 F25 stock
Post just did ATF pan+fluid @ 191k miles!!!!!!!!!!!!
28i xdrive prod date:11/11
original water pump btw.
job cost me $400 @ indy in Huntington Beach area
before job I would get a ton of shuddering when engine warms. I still have to do some more driving to see if that remedied it but I was expecting the shudder to be from the transfer case, which has seen its fluid change and reset @ 175k miles. When the mechanic checked the worm gear of the transfer case during the atf, for possible repair, he said it looks fine.
Also during the mornings from a cold start, my trans would whine and I am sure it is because the fluid was low because I pulled the check plug without the car being in neutral and lost some fluid. I looked at the pan but didn't take pics or keep it. The magnets had a fair share of metal shavings and the fluid looked darker. Since I didn't have a pair of gloves on, I didn't rub the fluid between my fingers to check the viscosity but I dipped a piece of white paper into it and can see that the fluid had discoloration throughout!
So far my shifting has become smoother but I still get a slight kickdown but I plan to reset the adaptations using ISTA and maybe that will clear that up. And so far no shudder but I have only put about 75 miles on but so far so good.
btw- the shuddering would occur when the trans was in between shifting, and it stopped or didn't occur in between shifting if I was in Sports mode [shift stick over left].
I am happy I do not have the problems that come from those turbos since my motor is the last I6 na. But I do have the engine tick at cold starts and so far BMW NA doesn't want to cover me and the problem has a 10 year unlimited mileage warranty so I will be contacting DOT or someone for some help! Other than that, this car is ridiculously reliable, because I have been racing through mountains and even been off roading and in deep snow! Only component I lost was a wheel bearing but it didn't leave me stranding, just would sound like you have a flat tire when you're driving.
Its almost time for my 10k oil change so I would like this time to send some oil in for testing.
      02-25-2018, 10:16 AM   #2
marc x
The shop used TopTec 1800 ATF
      02-27-2018, 07:57 PM   #3
Bimar
Bimar's Avatar
800
Drives: Bmw X
191k Miles, damn! I presume it’s the N20 engine.
      02-27-2018, 08:59 PM   #4
BIG_KID
BIG_KID's Avatar
68
Drives: 2011 X3 28i
11/11 should still have the N52 I6 naturally aspirated engine
      03-01-2018, 02:01 AM   #5
marc x
Ugh I still have shudder!! I read a post saying t could be the front wheel axlesa
It is the straight 6.
And the engine light is telling me to replace my cats, the book says a five hour job, so I will do half and pay an Indy to the the other half, since you have to remove the engine from the motor mount to get one of the manifolds w/ cats replaced. The parts are being delivered in a few hours.
      03-13-2018, 06:50 PM   #6
malicem3
Drives: 2022 X3
Not gonna see very many N20's at 191k that haven't had a major failure (i.e. timing chain). I6's on the other hand... especially the N52 are the best.
      03-28-2018, 02:16 PM   #7
marc x
Did the oil change and have the results of the oil analysis;
Even though I thought I topped off with 0/40, it was 0-30 from the dealer that was used, I confused it with another car. So this has seen all 0-30 dealer oil for this interval.
      03-29-2018, 11:02 AM   #8
epiphone3
Drives: 2013 BMW X3 35i
Is this the first time you've done the ATF and filter change on this transmission?
      03-29-2018, 01:21 PM   #9
marc x
Yes it is the first time
      02-24-2020, 10:59 PM   #10
marc x
Shudder is gone
replaced transmission with one with about 70k miles on it; and I re-used my valve body!
X3 drives like new again and the shudder is 100% gone now!!
      02-25-2020, 08:25 AM   #11
Wgosma
Drives: 2012 F25 X3 28i (N52)
Did you in fact replace the CATS?
At what mileage did you replace Oxygen sensors?
Thanks/Bill
FYI...Oil analysis - (I have same motor) at 75K mile mark: (I had shop change my tranny fluid/pan/filter at time this motor oil analysis was run.
      02-29-2020, 10:30 AM   #12
marc x
cats and o2 @ 189k;; my last BMW cats lasted same mileage and I put two engines in that before getting rid of it.
      02-29-2020, 10:33 AM   #13
Wgosma
Thanks. The CATS I think should have given longer life. O2 sensors did quite well however!
Tags
miles, original, reliability, water pump, zf8
