06-25-2015, 01:10 PM | #1607 | |
Rep 40,769
Drives: 2018 Alpina B6 650ix GC
Did you allow for an hour before testing the closing functionality?
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
06-25-2015, 05:07 PM | #1608 |
Rep 11
Hello again! After a long absence in wich i've been reading and doing only about FSC codes I thought I finaly do some coding on my X3. But I came across with the problem from the picture below when I tried to save CAFD files. Does anyone have any ideea what is missing in there? Thanks in advance.
06-25-2015, 05:08 PM | #1609 | |
Rep 40,769
06-26-2015, 02:27 AM | #1610 | |
Rep 81
Drives: X3 F25 (2011), X5 F15 (2017)
So let]s make summary until now: 1. Mounted all hardware and wired according to schematics (those printed out from similar car with original 316). 2. Battery connected and all starts worked automatically, except front cabin button (in schematics named TOEHKI and connected to A16 CAS connector A16*1B pin39. 3. On CID no menu screen for opening height limit. 4. Ater this option 316 added to SALAPA and FA written to the car. No any outgoing effect. Questions- Can I be sure that new FA changed something inside the car?? How to verify, that FA is correctly updated? I don't know what code value enable CID screen? Thank you for help. |
06-26-2015, 05:48 AM | #1611 | |
Rep 40,769
You can use .NCD / CAFD Tool, and compare .NCD files from ECU coded with 316 and without so see what FDL's have been chnaged: http://www.bimmerfest.com/forums/sho...d.php?t=749668
06-26-2015, 09:44 AM | #1612 | |
Rep 81
Will check it out and come back later |
06-28-2015, 04:12 PM | #1613 |
Rep 81
So I was able to find:
HU_CICHB > EXBOX 3001 > BACKDOOR_OPENINGANGLE = aktiv Now height limit setting screen is active. But still not able to find anything about TOEHKI button. Button is connected to CAS, but cannot find any value to wake it up. I believe something is wrong with my coding procedure- Now I'm chenging all values manually- select known function and change value. But, correct me if I'm wrong- If I add option 316 to SALAPA, it must update all related ECU's at once for full functionality. How to do this exactly? By TAL?? If I'm there, I don't know what to check in boxes there. Afraid to do something wrong. I believe I flashed HKFM, I see CAFD, but other ECU's values not changed to work properly with HKFM. I'm slightly getting lost in this Can you help a little?? |
06-28-2015, 04:28 PM | #1614 | |
Rep 40,769
HKFM is the one module where coding changes require car to go to sleep (1 hour) before changes kick in, so testing FDL Codes involves a lot of waiting.
07-02-2015, 05:18 PM | #1615 |
Rep 3
Need cable + software
Can somebody please send me a link to buy cable and pm me softwares required.
And is there any new step by step guide like 1st post or the same guide should still work ? Thanks in Advance |
07-03-2015, 04:32 AM | #1616 | |
Rep 40,769
ENET Cable: http://enetcables.com/
07-05-2015, 10:10 AM | #1617 |
Rep 13
F25 3AG Coded.
I seem to have a working 3AG reversing camera.
My thanks to Shawnsheridan and Sprollonis without whom I would still be backing into walls. My thanks also to all the other posts which helped too. A tip for any other newbie coders out there who like me think coding is writing computer software or data, when adding 3AG and the experts say code in relation to SVT files they mean select the item "code" from the right click context menu. No data input is needed. It becomes self explanatory once you actually do it Shawn the only thing I could not "code" was TRSVC. The context menu was greyed out. I guess TRSVC was added after editing the FA as it was not there in the original SVT files |
07-05-2015, 12:21 PM | #1618 |
Rep 40,769
You first need to inject CAFD into TRSVC and VO Code it.
07-05-2015, 04:54 PM | #1619 |
Rep 13
Which CAFD
07-05-2015, 04:59 PM | #1620 | |
Rep 40,769
Hopefully CAFD takes to ECU. If not, repeat process using the next oldest CAFD until one takes. If none of the CAFD's take, then you will need to flash TRSVC, but cross that bridge if and when you get to it.
07-05-2015, 09:46 PM | #1621 | |
Rep 2
07-05-2015, 09:48 PM | #1622 |
Rep 40,769
No. This is for F-Series only. E-Series is completely different. You need a DCAN Cable, EDIABAS, NCS Expert, and SP-Daten to code E-Series.
07-06-2015, 05:32 AM | #1624 |
Rep 40,769
PM sent.
07-06-2015, 11:52 AM | #1626 | |
Rep 13
Detect CAF
When I try to Detect the CAFs I get a PSdZ error. I suspect because my Data folder does not have the relevant CAFs. Just guessing of course. When I started this project I was using v.55.4_PSdZData_Lite but kept getting a FA error. I then tried the full version which allowed me to get a working camera but no CAFD for the TRSVC appeared. The controller module is the later part number 955 rather than the 256 that I ordered. Is it possible this later part needs more up-to-date CAFs? Hopefully I have attached some pics that may help. Many thanks for your interest. Ron |
07-06-2015, 11:54 AM | #1627 |
Rep 40,769
It means TRSVC must be flashed.
07-06-2015, 11:55 AM | #1628 | |
Rep 3
