11-26-2011, 11:35 PM | #1 |
Rep 28
Drives: Estoril Blue M235i
Shift Paddles question
How do they work? I pulled the left and right ones randomly while driving around town/freeway - nothing happened. I could not find any set up in the iDrive. Any ideas?
Thanks!
2011 Deep Sea Blue 328i Convertible
2012 Vermillion Red X3 35i, Premium, SAP, Tech 2014 Estoril Blue M235i, Premium, Tech, DAP 2015 Melbourne Red X3 35i, M-Sport, Premium, Tech, DAP, DHP |
11-27-2011, 12:10 AM | #3 |
Rep 28
I just went and tried that. I could use the shifter to change the gear from between M1 <-> M8 but paddle shifters did not thing to me. Should I bring the car to the BMW service?
11-27-2011, 12:18 AM | #4 | |
Rep 1,041
If the shift lever is in the left, manual position, the paddles should work all the time and the car should stay in "Manual" mode. Sounds like the paddles are not working at all and it's time for a trip back to your dealer. Last edited by Lotus7; 11-27-2011 at 06:58 AM.. |
11-27-2011, 06:56 AM | #5 |
Rep 272
The paddles will not allow you to over or under rev the engine. If you are cruising and in 8th gear, the right paddle won't do anything. When you shift using the paddles you see the gear displayed in the instrument panel.
Rich
'96 911 C4 Cab (276,000 1 owner smiles) '11 X3 35i Black Sapphire/Beige,SAP, CP, CWP, DHP, PREM, TECH, Sat radio, Hi Fi, BMW apps, smartphone, 19" w/mixed performance tires. |
11-30-2011, 04:09 PM | #6 |
Rep 28
Car has been in dealer since Monday. They haven't figured out what's wrong. Paddes were replaced but still not working. They are waiting for a call from a BMW engineer from New Jersey...
Since the manual shifting works, it must be either paddle or wire issue, right? What do you experts think?
11-30-2011, 04:33 PM | #7 | |
Rep 1,041
Hope they gave you a nice loaner to drive. |
11-30-2011, 07:19 PM | #8 | |
Rep 1,876
Not true. Will still shift when in the non-sport setting, but quickly reverts to "D" if you're not shifting to keep it where it thinks it should be.
11-30-2011, 08:21 PM | #9 |
Rep 2,522
11-30-2011, 11:26 PM | #10 |
Rep 1,041
All of the above is pure speculation, including my own comments. It may be a simple cable connector that's not fully seated, a defective steering column connection, a defective bus interface at either end, or even a software issue in the transmission controller. It may be something entirely different.
If the BMW techs at your dealership, using BMW's advanced diagnostic hardware and software haven't been able to easily find the problem with access to the car and their diagnostic equipment, there's not a very high probability that the collective speculation of a bunch of guys who have never seen your car will do any better. Good Luck and do keep us "speculators" informed. Inside of the ZF GA8HP showing the planetary gears that those paddles ultimately control. |
12-01-2011, 07:12 AM | #11 | |
Rep 60
12-01-2011, 07:45 AM | #12 |
Rep 1,041
It's a "brave New World" out there car wise. These new vehicles are so different from previous generations, that many of us (and most auto service techs) are familiar with, that diagnosing what would have been a relatively "simple" problem now involves tens of thousands of dollars worth of dedicated computing hardware that only the factory shops have access to, PLUS knowledge of very sophisticated computer and communication systems.
The cars are virtually impossible to modify in any serious way, and, as in this case, (and many more that have been discussed on this Forum) the dealer's Service Dept. employees "don't have a clue" and must communicate with some guy in Bavaria who may be only one of three people in the universe who understand some small aspect of the vehicle design well enough to come up with the solution. Sorry for the rant, but I miss the "old days" when all you needed was a 12V. test light and a feeler gauge to set the "points" to get any car running. Those days are gone forever. Just try and buy a service manual for a X3. Not possible at any price. |
12-01-2011, 10:39 AM | #13 |
Deckhand
Rep 389
"Sorry for the rant, but I miss the "old days" when all you needed was a 12V. test light and a feeler gauge to set the "points" to get any car running.
Those days are gone forever." I agree but so long as you are not referring to a British built car circa 1970-1980 - those were the dark days.... |
12-03-2011, 10:52 PM | #14 | |
Rep 28
12-03-2011, 11:16 PM | #15 | |
Rep 1,041
Most modern vehicles, including the F25 cars, are really a rather complicated computer networks on wheels that just happen to have an internal combustion engine and some tires. The way general computing is moving to the use of on-line "cloud" applications hosted on an unknown server half-way around the world away, it won't be long before the dealers will not have any need for any diagnostic equipment at all. When your car fails all of it's diagnostic data will be read by that remote cloud system and the repair instructions will be coughed back to the car. A technician, possibly a non-human robot device, will either repair your vehicle or stamp it unworthy of repair and separate it into it's component compounds for re-cycling and send you a bill for the replacement current new model, with credit, of course, for the components reclaimed from your old "heap". As I said a few posts back "It's a Brave New World" and it's rapidly becoming "Braver". That's why I'm never going to sell my Lotus. It has only one microprocessor (controlling the fuel injection and ignition), and has no network connected to anything. A F25 has approximately (30) microprocessors or programmable gate arrays, depending on options. Which one do you think will have the higher probability of running 10 years from today? Last edited by Lotus7; 12-03-2011 at 11:26 PM.. |
12-05-2011, 09:00 PM | #16 |
Rep 28
Well, it was wiring issue as I have suspected. One pin of the connector was collapsed. It's sad to see that it took dealer 7 working days to fix it.
12-06-2011, 09:48 AM | #17 |
Rep 221
At least you got it fixed.
2012 X3 35i | Deep Sea Blue | Oyster |
Packages | Sports | Cold Weather | Cold Weather 2 | Premium | Technology | Premium Sound |
12-06-2011, 11:05 AM | #18 |
Rep 28
Of course they have to fix it or give me a new car since it only has less than 200 miles.
My point is that a decent mechanic would be able to trace the wire from paddles to the transmission controller and check out the connectors without waiting for "advanced" tester. 8 days of rental car + several hours of labor for this? Isn't it why BMW cars are expensive?
06-27-2014, 06:14 PM | #19 | |
Rep 14
Paddle shiftting problrms
Even in manual mode the upshift paddle won`t work. The gearbox is stucked in first gear and no matter how many time I pulled the paddle for the next gear, it won`t change to the next gear. Is very weird since it only happens some times. Any suggestions??? |
02-21-2021, 05:21 PM | #20 | |
Rep 44
BMW call it something like: Instrument cluster switch control module Youcannic has an article showing the procedure here: https://www.youcanic.com/article/clock-spring Just ensure you’re confident; disconnect battery, have right tools & part, plan & record exact steps! My car is fully maintained & otherwise runs & performs perfectly It seems fairly common for these clock spring assemblies to wear out; not just on BMW’s; across manufacturers. Good luck to anyone who reads this |
