05-01-2019, 08:21 PM | #1 |
Rep 2
$2300 for Gear Selector Switch Replacement, to fix Chassis Stabilization message
I have a 2014 X3. Starting from late last year, it has been functioning weirdly, with 'Chassis Stabilization', 'Drivetrain Malfunction', 'Transmission Malfunction' and 'Transmission Overheated' warning messages popped up from time to time.
I took it to the BMW dealership for a diagnosis. The first time, they updated the software system for me, and it went fine for 1 week or so. I brought it in for a second diagnosis after the problem occurred again. It took them 2 weeks to find out it was the Gear Selector Switch problem, and they recommended me to do the replacement, with $1300 for the part and $1000 for labor. My questions are - 1. Does this sound a solid root cause? 2. Does the cost sound reasonable? 3. Do you guys recommend me to get it fixed by BMW dealership or somewhere else? |
05-02-2019, 10:37 AM | #2 |
Rep 482
Part is 911$ at ECSTuning.
Replacing it is not hard. Need some trim tools to lift the cover surronding the gear selector. I did something similar on an older BMW model. The selector was held in place by 1 or 2 screws and some clips. Then pull out, unplug. Plug in the new unit, put in place, screw in and replace the trim. Should be plug and play. For more info, I would look up the "New TIS" online repair procedure, then make an informed decision. GL and let us know how it works out
Stable:
e92is f25 N52 e83 N52 e46ci M54B25 (e53 N62 - sold, R.I.P. e39 M54B30) |
05-02-2019, 12:56 PM | #3 |
Rep 470
$1000 in labor to replace the gear selector? It takes 10 minutes tops to get access to it!
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280' |
05-03-2019, 09:21 AM | #4 |
Rep 71
Yeah, should be a really easy replacement, overall. I wouldn't pay them to do it. If you aren't mechanically inclined find a friend who has even basic knowledge in working on cars and they should be able to do it.
As for whether it's the root cause.....maybe? Really tough to tell; I guess I'd wonder why or how those types of warnings would run through the gear selector, but electrical/electronic bugs can be weird. |
09-28-2023, 06:27 PM | #6 | |
Rep 1,910
Tags |
chassis stabilization, check engine light, drivetrain malfucntion, transmission malfunction, transmission overheated |
