      04-13-2011, 01:39 AM   #1
abailey08
Drives: X3 xDrive28i
How do I fold my mirrors in?!
It doesn't look like I have the power fold option.... and when I push (albeit, not as hard as I could) on the mirrors, they don't fold very easily.
Anyone have any idea if they move at all before I break my mirrors off?
      04-13-2011, 02:27 AM   #2
Bimar
Bimar's Avatar
800
Drives: Bmw X
Its an option, if u didn't buy it u doing manually in my mind it should be standard in a luxury car.
      04-13-2011, 04:46 AM   #3
Nahoa
Do you have a button on the driver's door, back and to the left of the mirror adjustment pad? On mine that folds and unfolds the mirrors. They don't seem to work the same as the ones on my 330i, so pushing on them might not fold them like it used to. I can try later today.
      04-13-2011, 09:22 AM   #4
abailey08
I have a button, a little black thing, but pushing it doesn't do anything (the button doesn't even compress). Thanks in advance for taking a look!
      04-13-2011, 11:14 AM   #5
LEDZEP
LEDZEP's Avatar
417
Drives: 2009 E70 & 2011 F25
Sounds like you're identifying the right/left mirror selection button. It would be near that one - to the left of it. If I recall, there is a small white icon of some sort on the button.
In the US this is part of the Premium Package. If you don't have that package you don't get folding mirrors.
I think it is bad luck to be superstitious
      04-13-2011, 11:15 AM   #6
flash3
Drives: X3 28i
^ you should be able to fold them manually w/o the prem pkg, no?
      04-13-2011, 11:21 AM   #7
Lotus7
Drives: xxxx
As LEDZEP said, there is a button to the left of the mirror selector switch if you have the option.
      04-13-2011, 04:52 PM   #8
Waffle
Waffle's Avatar
19
Drives: BMW F25 X3 xDrive20d SE
If you have the option, when you press the lock button on the remote and keep it held down for a few seconds, the mirrors will fold and any open windows will close.
black sapphire | black nevada leather | wave wood | 19" double spoke alloys | xline | xenons | business advanced media package | electric seats | dab | extended storage | grey shade band | auto
      04-13-2011, 05:01 PM   #9
abailey08
I definitely don't have the button (and no premium package).
Does this mean my mirrors won't fold at all? even manually? I went out and tried pushing again, but they don't seem to be budging.
      04-13-2011, 05:31 PM   #10
Lotus7
Drives: xxxx
The standard (not power folding) mirrors can be folded manually. Press straight back on the outer edge of the mirror housing. It takes about 20-25lbs. (10 kilos) of direct force. Once you get "through" the detent, the mirror should rotate very easily. It does take a "serious" push to get them to move at first. I hold on with both hands so as to not spin the mirror too fast once it starts to move. The mirror housings will fold back about 35 degrees. They won't fold far enough to touch the windows.
Don't be afraid of hurting anything. the mirror is designed to fold, just not by itself.
If pressing very firmly doesn't fold the mirrors, you can always try hitting the mirror housing with a 4lb. Engineering hammer.
That will certainly do it. JUST KIDDING!
      04-13-2011, 05:39 PM   #11
sfax
sfax's Avatar
Drives: BMW X3 2011 F25
The standard (not power folding) mirrors can be folded manually. Press straight back on the outer edge of the mirror housing. It takes about 20-25lbs. (10 kilos) of direct force. Once you get "through" the detent, the mirror should rotate very easily. I hold on with both hands so as to not spin the mirror too fast once it starts to move. The mirror housings will fold back about 35 degrees. They won't fold far enough to touch the windows.
How do you measure the actual force required to fold the mirrors Lotus?! Does the front door on your house have a lbs rating? Would 30 lbs be enough to take you on in an arm wrestle?
F25 xDrive20d SE __ professional multimedia package | dynamic package | climate package | 309s | xline | xenons | electric seats | folding mirrors | business speakers
      04-13-2011, 05:53 PM   #12
Lotus7
Drives: xxxx
Just a "guestimate" (hence the "about") based on lifting too many packed carryon bags.
      04-13-2011, 05:54 PM   #13
Lotus7
Drives: xxxx
Just to prove that the manual mirrors actually do fold:
      04-13-2011, 08:23 PM   #14
Nahoa
Not true on the F25 (least in the US) as far as the mirrors. Haven't tried the window portion.
      04-13-2011, 08:32 PM   #15
flash3
Drives: X3 28i
Lotus, thanks for posting those pics!
      04-13-2011, 09:03 PM   #16
Lotus7
Drives: xxxx
Please ignore the color balance. The Vermillion Red is really much more blue and not so orange looking. I didn't bother to correct it before posting.
Also should have labeled the shots:
"Normal" Half-Folded' and "Fully Folded"
      04-13-2011, 09:09 PM   #17
Nahoa
Are we still talkin' mirrors?
      04-13-2011, 09:15 PM   #18
jijioben
Drives: 2011 F25 X3 35i
Great info as usual, Lotus7!
      04-13-2011, 09:16 PM   #19
Lotus7
Drives: xxxx
Are we still talkin' mrrors?
Isn't this the photography forum or is it the baking, quilting and pottery forum?
      04-13-2011, 09:47 PM   #20
abailey08
Thanks guys And for the amazing description, Lotus.
