09-19-2012, 07:03 PM | #1 |
Rep 42
Tire Pressure Sensor failures
2012 Loaded X3 w/M-sport 35i.
Tire pressure monitoring system sensor failures started poping up on the screen about every 5 minutes while driving. This is the active design (rather then the passive ABS variant). Part is in Germany -- apparently there is a new part # for this, so there may have been issues? I will post the numbers. The dealer put 16 miles on the car -- WTF? Is that normal for something like this with 200+ failures logged in OBDII? Thanks, -mark
2012 X3 xDrive35 - all options except HUD |
09-19-2012, 09:04 PM | #3 |
Rep 42
Nope, didn't touch anything. Entire car is 100% stock.
-mark
09-23-2012, 02:09 PM | #6 |
Rep 42
The error is that the TPM sensor is unable to communicate. It's a problem with the wireless sensors, not the tire pressure itself.
Note that the 2012 X3 is a wireless system. I'm also told that the sensors are different on the M-wheels that I have, so the failure may be isolated to folks with 2012 M-sports. The dealer told me that they had to reproduce the failure and as such had to drive 16 miles. Why is that necessary? I have OBDII that logs the events -- seems very suspicious to me. Mark
10-10-2012, 01:34 PM | #7 |
Rep 161
I have a 2011 X3.5 M-Sport, may build, and am having the same problem. Got the much appreciated software update, but it didn't solve the TPM issue.
10-11-2012, 06:19 AM | #8 |
Rep 11,839
Drives: MY24 G01 AW Msport
so solution is replace tpms in the wheels
