07-18-2011, 10:29 PM | #1 |
Rep 1,334
City slicker with an occasional Ski Trip
Hi. I live in S. California and used to go up to Mammoth Mountain 1-2 times a month. My friends and I never had a 4 wheel drive car so when the weather was bad we would have to put on the snow chains. That kinda sucked doing it at like 4 am. Earliest we've had to put chains on was about Bishop.
Onto the point of my post. Now that I will soon have an X3 .. I'm assuming with the Goodyear LS2 All Seasons .. is it safe for the worst weather driving up to Mammoth Mountain and into the ski resort with no chains? 75% their worst weather? I'm sure this has been discussed on other forums, but whatever. Out of all the times I've been up there I think 90% had chains on when the weather was bad. Maybe 90% of vehicles tend to be 2 wheel drive? The ones that didn't have chains were big 'ol "real" looking 4x4's with big knobby tires. How bout buying a set of winter tires/wheels? Then safe with no chains? That's a bit too expensive though .. Would the drive up there (330 miles) on the asphalt suck on the winter tires? Thanks.
E92 M3 - DCT - 20" BBS LM-R - KW Clubsport - Akrapovic Exhaust - Powerchip Tune - Arkym Aero Kit - HID Halo |
07-18-2011, 10:46 PM | #2 | |
Rep 1,041
If 90% of the cars on the mountain are using chains, you probably won't be happy with the performance of LS2 All Seasons. A dedicated set of Winter Tires would probably be a good bet. Most contemporary Winter tire designs work perfectly well on dry roads as long as the temperature is not too warm (above 50 deg. F., or so) and as long as you don't try to push them to maximum cornering limits or excessive speeds when dry. I've used Winter tires in the Midwest during seasonal changes in the spring and fall on warm days with no problems at all. Extensive use on warm or hot roads will wear the winter tires out pretty fast, but otherwise won't cause any serious problems for you. The X3 Manual section related to chains is quoted below: Snow chains Fine-link snow chains Only certain types of fine-link snow chains have been tested by the manufacturer of your vehicle, classified as road-safe and recommended. Consult your service center for more information. Use Use only in pairs on the rear wheels, equipped with the tires of the following size: ▷ 205/65 R 17. ▷ 225/60 R 17. ▷ 245/50 R 18. No snow chains with tires of size 245/45 R19 Do not mount snow chains on tires of size 245/45 R 19; otherwise, the vehicle can become damaged.◀ Follow the chain manufacturer's instructions. Make sure that the snow chains are always sufficiently tight. Retighten as needed according to the chain manufacturer's instructions. Do not initialize the Tire Pressure Monitor after mounting snow chains, as doing so may result in incorrect readings. When driving with snow chains, briefly activate Dynamic Traction Control if necessary. Maximum speed with snow chains Do not exceed a speed of 30 mph/50 km/h when using snow chains. |
07-18-2011, 10:50 PM | #3 |
Rep 969
Check the official state rules. In Utah, you need AWD/4WD or chains on certain mountain/canyon roads when there are winter conditions (they do check this and will turn away 2WD cars without chains). CA has similar rules around Lake Tahoe, and I'm sure they apply in the mountains around Mammoth as well.
07-18-2011, 10:54 PM | #4 |
Rep 1,334
Wow.. I ordered the M Sport which has the 19" tires... so according to that I cant even put chains on it >.<
Would Winter tires alone be okay for "just received 3-4 feet of snow overnight" days? Would the all seasons alone be okay for less than that. The town of Mammoth and the main roads do have snow plows doing their thing throughout the night/day.
07-18-2011, 11:13 PM | #5 | |
Rep 1,041
Haven't had any experience with LS2's, but the reviews are not the best. I've tried the Pirelli P7's in snow and they’re actually pretty good in up to 2 inches of fresh snow but barely acceptable on ice. If all I had available were "All Seasons" and if the snow was being measured in "feet", I'd stay home! Have used dedicated winter Blizzaks (old LM-25's) on a Suby Legacy and on our Audi A4 wagon (both all-wheel drive) and they work superbly. The Suby would easily go through deep snow and was only limited when it got so deep that the car bottom "floated" the tires. The A4 was almost as good, and was again limited by ground (snow) clearance only. Last edited by Lotus7; 07-18-2011 at 11:24 PM.. |
07-18-2011, 11:28 PM | #6 |
Rep 53
I encountered the similar situation where the All-Wheel Drive world was new to me and I had asked about driving in snow conditions. I had a great recommendation for SCC Super Z6 Cable Chains. It turns out I was hit by a freak snowstorm in Yosemite where they had to close the roads. After opening the roads it was mandatory to have chains on the vehicle before they allowed us to leave. We had tried to get out of the parking lot without the chains and the car would not get traction. With the chains...Piece of cake.
I have the 18" Potenza All Season tires that came stock on the car. I highly recommend these chains... http://www.scc-chain.com/traction%20pages/Trac_SZ6.html |
07-19-2011, 12:16 AM | #7 |
Rep 764
I don't believe CHP allows anything but chains when "chains required" is posted. Does not matter what setup your car has. Never forget driving from Mammoth to Bishop with chains and a wiseass in a red corvette doing about 45 mph went flying by us. We saw him in Bishop with his fenders shredded.
07-19-2011, 12:18 AM | #8 |
Rep 1,334
I have the stock 18's that came with my M3 .. they measure 8.5 x 18 / 9.5 x 18 .. is it okay to put staggered setup on the X3? Maybe I can dismount the tires on those rims and put some winters on there.
07-19-2011, 12:22 AM | #9 | |
Rep 1,334
07-19-2011, 12:23 AM | #11 | |
Rep 1,334
07-19-2011, 12:59 AM | #12 |
Rep 752
Drives: 2020 X5 M50i
I am not sure what the law requires in California. I have traveled over the mountain passes here in Colorado for years with all wheel drive and all season tires with no chains and no problems. This is in some of the worst winter weather we had, traveling over Vail pass, Monarch pass, Red mountain pass etc... The snow tires are always a bit better as others have pointed out, and especially nice if you have two sets of wheels so you can swap them for that weekend run up the mountain.
07-19-2011, 01:19 AM | #13 |
Rep 1,041
Just wanted to comment that it feels pretty bizarre to be writing about snow tires and chains today. The real temperature hit 98deg. F. here (Midwest) today and the prediction is for a Temp/Humidity index reading of 107 tomorrow. Thinking about tire chains today just doesn’t feel right!
07-19-2011, 01:55 AM | #14 | |
Rep 3,855
07-19-2011, 03:41 PM | #15 |
Rep 517
Good weather then this week, sfax? Mebbes it'll rain properly next week.
G26 420d Gran Coupe MSport Black on black, MSport Pro Pack, Comfort Plus Pack, Harman Kardon audio
07-19-2011, 03:57 PM | #16 | |
Rep 470
TODAY Rain High: 18° ** Low: 13° TOMORROW Rain High: 14° ** Low: 12° THURSDAY Mostly Sunny High: 17° ** Low: 11° FRIDAY Partly Cloudy High: 16° ** Low: 11° SATURDAY Partly Cloudy High: 16° ** Low: 11° |
07-19-2011, 04:27 PM | #17 | |
Rep 1,560
07-19-2011, 04:34 PM | #19 |
Rep 3,855
haha, I know it's worse away from the south east - lived in Manchester for 3 years where it used to go months without a dry day! After posting that earlier, this evening it was glorious weather. I was sat in the garden in the blazing sun for about 20 minutes... and then it went in and I got cold!
07-19-2011, 08:56 PM | #20 | |
Rep 969
07-20-2011, 12:53 AM | #21 | |
Rep 1,334
07-20-2011, 03:35 AM | #22 |
Rep 210
Drives: X5 M50i
I live in Park City Ut and drive to Mammoth a couple tmes a year. Moved here from LA. In my opinion you would not need dedicated snow tires on your car for the trip. Just All Season. SoCal would not be a friendly place for dedicated snow tire. Last year I was driving to Mammoth while they were recieving 54" for the day and CHP was allowing 4wd as long as people had chains in the car... I thought this was a bunch of BS...I had never heard of that before. I bypassed them and went up the 6 toward Tonopah and did not have an issue.
The other thing I would add is conditions can get just just right in the mountains where no combination of snow tires and AWD will make a bit of difference... It just gets that bad. Other observations...roads are plowed. Once it stops snowing conditions improve greatly and very quickly. So worst case scenario just wait. With all of that said, I am going with a dedicated snow tire. Blizzack LM60 just becasue I live in the stuff. If I didnt live in it...No way would invest. The LS2's or any other all season tire will get you around just fine... Especially for the weekend trip up! |
