      06-03-2013, 06:37 AM   #1
stumblingtrout
Inspector Gadget
Drives: MY14 X3 35d M
Rust?!
Surely not.
Pictures show:
1) Underneath rear nearside light cluster
2) Top of bonnet, nearside.
Not dead bugs either. I can't scratch these off.
Car is 3 days old, 100 miles and had been Seal & Protect treated at the distribution centre in Thorne.
Thoughts?
MY14 X3 35d M-Sport. Born 19/04/13, Delivered 31/05/13. Alpine White, Red Brown Leather, Brushed Aluminium, 19" 369 Alloys, BMW Media - Professional, Visibility Package, Access Package, Electric Seats w/ Lumbar, Variable Damper Control, Panoramic Roof, Extended Storage, HUD & Black Panel Dash, DAB, Reversing Camera & Top View, Heated Steering Wheel, Heated Rear Seats, Apps, Internet, BMW Loudspeaker Professional... & More.
      06-03-2013, 07:21 AM   #2
Want the thrill
2022 X4M40i  [10.00]
Look like iron deposits to me. Auto Finesse Iron Out will remove those or a clay bar might do the trick as well. Here is a link to the iron out:
http://www.autopia-carcare.com/auto-...Fanm7Aodn3oAiQ
      06-03-2013, 07:37 AM   #3
UKMS
UKMS's Avatar
United Arab Emirates
112
Drives: X7 40i
My thoughts would be to have it looked at by BMW before you try any DIY solutions ....... or at least give them the chance of looking ..... a pain for you as the dealership is so far away ...... I'll PM you a contact as your man is off at the moment
MS
X7 40i - Mineral White - Merino Coffee - Lots of toys
      06-03-2013, 08:45 AM   #4
roadkillrob
Drives: 08 335i,22 X3M, 2012 C63 Black
Others have posted up similar issues, seems that they get iron bits stuck to the paint form the train ride that then rust and just need cleaned off. They may have sealed it, but doesn't look like they cleaned it well before they sealed - would need to have a clay bar used before the sealer to get all the deposits off the paint. Iron X or similar will remove it or a clay bar, but either may remove the sealer, so you may want to got back and have them clean it all and re-seal to do it correctly.
2022 X3M Brooklyn Grey
2008 E93 335i FBO
2012 Mercedes C63 Black Series Alanite Grey
      06-03-2013, 09:53 AM   #5
lbjgh
lbjgh's Avatar
Drives: 2013 AW X3 M-Sport
I have the rust marks on my AW car as well.
It appears on the plastic bumper covers too so it's obviously contaminants in the paint oxidizing.
A local detailing shop advised that this issue is very common on white cars from ALL manufacturers.
      06-03-2013, 10:32 AM   #6
mac10
England
Drives: Alpina D3 Bi-Turbo (SOLD)!
Hi,
I thought this might be of interest to you!
I would still take it back first though and show BMW agent what a poor job they have done in pdi. etc.
Good luck in getting it sorted!
Mac.
      06-04-2013, 04:55 AM   #7
stumblingtrout
Inspector Gadget
Cheers for all the replies - I figured it wasn't the body rusting as I assume the patch below the rear light cluster is plastic rather than metal.
Is it likely that I can't scratch these things off because they have waxed and polished over the top (seal & protect) and if so are they going to have to strip it and reapply it properly?
Cheers!
      06-06-2013, 03:03 AM   #8
stumblingtrout
Inspector Gadget
MS
MS - Cheers, I've been dealing with Andrew... and I'm taking it into my local dealership today as the bodyshop guy is in... So i'll see what he says!
      06-13-2013, 08:46 AM   #9
stumblingtrout
Inspector Gadget
Update:
Car is booked in for a machine polish at the Elms BMW Bodyshop in Bedford... 4th July
I assume they will then re-apply seal and protect...
Update:
Email from BMW reads
You’ve pretty much nailed what we will do on the head. We will clean the car, machine polish it, and re-apply a fresh layer of seal and protect once complete. This is the process that we have been asked to undertake by BMW. I hope this is a satisfactory solution to the problem for you, please let me know if there is anything further I can do to help?
      06-13-2013, 06:15 PM   #10
Teemo Panda
*Bimmerpost Plasti Dip Guru*
Teemo Panda's Avatar
Drives: E53, E46-M3, E70, F25-X3
2013 BMW X3  [5.66]
That is one downside of having a white car.
Claying the Finnish should take it out
      06-14-2013, 05:15 PM   #11
JamRWS6
Drives: 2022 X3M Competition
Those should be clayed rather than taking an abrasive to the paint. A very mild finishing polish after claying to remove any marring is all that would be needed.
- 2022 X3M Comp
- 2021 X5 xDrive 40i
- 2018 F80 M3 (sold)
      06-15-2013, 06:44 AM   #12
stumblingtrout
Inspector Gadget
The problem is that these bits of fallout are trapped under the hard wax that BMW applied so they feel totally smooth to run your finger over. They need to remove the later of protectant in order to remove the fallout and then re-apply the seal and protect stuff.
      06-15-2013, 08:24 PM   #13
JamRWS6
Gotcha. I missed the part that a sealant had been applied on top.
- 2022 X3M Comp
      06-17-2013, 07:55 AM   #14
nyalpine90
nyalpine90's Avatar
7433
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
i came across couple of tiny spots by the gas door, is this something i can take back to bmw service center and get it repair under warranty or its out of pocket expense.
      06-19-2013, 12:58 PM   #15
stumblingtrout
Inspector Gadget
It's most certainly a warranty issue in my case...
If your spots are locked under sealant that BMW applied that yours should be the same. If they have settled after you got the car then you should be able to remove them yourself and it's not a warranty issue...
