      11-01-2020, 12:14 PM   #1
druvi
Drives: BMW F25 2.0d LCI
F25 Small Screen - Possible to fit Reverse Cam
Hi Guys,
I have an F25 2015LCI with HUEntryNav. I want to fix the 3ag reverse cam option. FOllewed the advice and see that an icam2 is required. When I try to code the HUENtryNav with 3AG it fails with the following error.
My question is can you retrofit 3ag icam on a 6.5 screen ? I tried coding multiple times but got the error right throughout.
Any Ideas how to fix this ?
Thanks,
[HU_ENTRYNAV - 63 - cafd_00000ded-003_015_039] Transaction type: cdDeploy; Message: TA started [TRANSACTION]
MCDDiagService<id=62649, job=com.bmw.psdz.jobs.uds.MCD3_PerformECUCoding, service=WDBI_PLAIN - WriteDataByIdentifier with unlimited Data-ID (plain
hex value), description=error: negative response : requestOutOfRange, link=HU_ENTRYNAV_63_ETHERNET> [DIAGSERVICE]
[] job failed with negative response error:
code: repeat job
description: Service WDBI_PLAIN returned a negative response with response code requestOutOfRange; LinkName: HU_ENTRYNAV_63_ETHERNET
severity: ERROR
[THROWABLE]
      11-02-2020, 08:59 AM   #2
aspame82
Mr
Peru
21
Drives: BMW X3 XDrive28i Xline 2017
I have f25 lci 2017 before retrofit to 5DL, i had Icam 3ag and 6.5 inches screen. Therefore, you should be able to do it.
for your info, i had an error like that it seems to be Vo code error for headunit. I solved it using feature installer and Vo Fix code to be able to make Vo code to headunit.
If you are interested i can send you the contact info from my coder who solve it.
      11-10-2020, 10:56 AM   #3
druvi
pic of head unit
Hi Aspame82,
thanks, by chance would you have a pic or part no of your head unit. I compared the two fa's and they are identical. Did you upgrade to SA609 ? Would you have a pic of your old one to snap for a pic ?
Cheers,
      11-10-2020, 01:25 PM   #4
aspame82
Mr
Peru
21
hi, pics:
View post on imgur.com
      11-11-2020, 01:55 AM   #5
druvi
Thanks
Thanks - this is mine pretty basic but the fa codes are the same. Are you still using this head unit or did you upgrade ?
      11-13-2020, 08:12 AM   #6
aspame82
Mr
Peru
21
it seems your unit is huentry instead of huentrynav. Maybe it is pre lci and icam would not work
Tags
3ag, f25, icam
