      05-25-2023, 02:41 PM   #1
bpwj76
bpwj76's Avatar
Drives: 2021 530i; 2016 X3 Sdrive28i
Stiff Brake Pedal at Startup
I have a 2016 SDrive28i with 110k miles. Recently, I'd say within the past two weeks or so, when going to start the vehicle it has a very stiff brake pedal and I get a message in the instrument cluster that I need to press the brake pedal first to start the car. Then after pressing the pedal even harder I feel a slight click in the pedal and the car starts. Normal feeling brake pedal returns once the car starts.
Any ideas as to what could be causing this behavior?
      05-26-2023, 08:00 AM   #2
bpwj76
bpwj76's Avatar
I think I may have a vacuum leak.
      05-26-2023, 11:00 AM   #3
slowblackx3f25
xdriv33
slowblackx3f25's Avatar
Drives: 17' BMW x3 F25 xDrive28i xLine
2017 BMW x3  [9.50]
it would throw a code.
whens the last time you did a brake fluid flush and refill as well as bleed the brake lines?
this must be done every two years...
      05-26-2023, 02:37 PM   #4
rcsup1
Drives: x3 35i
I have had the same issue for a while now. I definitely think its a vacuum leak from the brake booster. Have really looked into it. Could be the booster or possibly a one-way check valve that leads to the booster.
2011 F25 X3 35i |M-Sport Front Bumper Conversion|Largus Full Adjustable Coilovers|FTP Charge Pipes|Gutted Catalytic Downpipe|RB Oil Cooler Thermostat Delete|25 Row Oil Cooler|Custom Built Cold Air Intake|9"AEM Cone Filter Behind Kidney Grills With Outerwear|Precision Raceworks Coils|BM3 Stage 2 E30 Tune| BM3 Upgraded 8-speed TCU Flash|395mm X5M Front Brakes
      05-26-2023, 04:53 PM   #5
HighlandPete
Drives: BMW F11 535i Touring
Yes, sign of a vacuum leak. Not uncommon to have a firmer brake pedal at the first start, if a vehicle is not used for several days. If it is frequent, definitely get it sorted.
      05-16-2024, 02:34 PM   #6
GeorgeThe4th
Drives: 2016 BMW X3 xDrive 35i M Sport
I’m having this exact issue with my 16’ 35i. Firm brake pedal most mornings after been sitting for a couple hours. Replaced the grommet on the brake booster. Cheap seal. Wasn’t it. Next I might test or replace the one way valve and see what that does.
