      06-13-2021, 06:52 PM   #1
RL325xi
Drives: 2006 e91
Chassis stabilization warning 4x4 ABS
Sorry about the long story. Hope someone can help me on this and help others in the future.
2012 X3 35i 54k miles.
This happened yesterday. Right after I started my car put it in drive, "Chassis stabilization warning” with the yellow 4X4 ABS symbol. Message said “drive moderately. Avoid hard braking. Contact or drive to BMW” I pulled over Used bimmerlink to pull error code. It came back with a lot of codes
Some that I understand are
Under DSC
480686, Wheel speed sensor – approach detection faulty
48068C, Transfer case clutch temp shut down, possibly overheating
Under Integrated chassis
480114
D017A3
D017C5
D02C67
Under Transfer box
440117, four wheel distributor gearbox temporarily shut down
Under transmission control
CF2F02
DSC interface(actual wheel speed HL/VL?HR/VR 0x254) signal invalid
Under radar sensor
480512, speed – DFA_EMF frequency overlimit
D3AC8D, Signal error(status hydraulic function, id: ST_HYDFN) Sender: DSC_Modul- Qualifier
Was able to clear all the codes except those under DSC and Transfer case.
Tried to drive the car, it seems to be drivable without suffer any power lost and noise.
So I was thinking about it is could be the wheel sensor caused it. Drove the car moderately for around 4 miles to buy something then head home.
After the stop, It started right up with the same warning. Scanned it again with about the same error codes. Started to drive home. Within 30 seconds, I feel a cluck and new warning on the dash, it said Transmission malfunction, do not stop engine. Continue driving may not be possible after switch off engine.
Due to my situation, I decided to drive home(about 10 miles away). The car ended up in limp mode, idling fine, but felt like I only have the 4th gear.
After a very slow drive for 30 mins, finally home. I realized that I cannot shifted off from D( Can’t even go to R, N or P). Since I am home, I have no choice but to shut it down. When I restarted the car, to my surprise, I was able to put it to R. I also don’t have transmission malfunction anymore. Only chassis stabilization with 4 x4 abs symbol. I scanned it again to see anything new.
Under transmission
421474, sensor technology: Inadmissible deviation from output speed and wheel speed(actual wheel speed HL/VL/HR/VR, 0x254) within gear shifting or in a non-positive state
CF2F02, DSC interface(actual wheelspeed HL/VL/HR/VR, 0x254)signal invalid
Under transfer case,
44011C, Powertrain protection deviated
440117, four wheel distributor gearbox temporarily shut down.
BTW, Bimmerlink said that my transmission temp at 227 degrees.(wonder if I damage my transmission)
Do you think the wheel sensor causing all these??
      06-13-2021, 09:18 PM   #2
pungo
pungo's Avatar
961
Drives: Z4MC, X3-35i,525i, Corrado G60
Test the wheel speed sensor and replace if testing fails. A bad wheel sensor can cause all kinds of drive train issues/errors/failures.
RL325xi30.50
      06-23-2021, 10:56 AM   #3
Lurcher
Lurcher's Avatar
Drives: 2012 z4
^^ So this, replaced 2 on opposite corners 30 days apart recently
RL325xi30.50
      01-17-2022, 01:43 PM   #4
gopi4496
Drives: BMW X3 30DX
Hi,
New to the forum. not sure if I shd post my question here or start a new thread.
Encountered this today and wondering how to resolve.
TCM-Transmission Control Module -egs
48068C : Transfer box: Temporary fault, temparature
4809b0: wheel speed sensor, drive off recognition, front left
reg...
      01-22-2022, 04:14 AM   #5
pole1980
Drives: BMW X3 F25 & BMW X1 F48
Originally Posted by gopi4496 View Post
Hi,
reg...
have you ever replaced the oil in the transfer box? could be that you oil has aged and lost the lubrication properties and the mechanism overheats.
are your tires inflated at the right pressure? are your wheels oem and properly balanced?
      01-23-2022, 07:11 PM   #6
biofreak
Drives: 2015 X28i x3
I got the same error earlier today on a 2015 X3 28i with 85K miles. Along with it I also got several others like parking brake error, abs , restraint error etc. I should have taken a picture. The GPS started acting weird and showed that I was driving off the road. I drove the car in limp mode for a couple of miles until I could stop at a gas station. I switched off the car completely and waited for a couple of minutes and restarted it. All of the errors disappeared! I was able to drive about 125 miles back home with out any issues. I will have to take it to the local dealer and find out what happened.
      01-25-2022, 03:14 PM   #7
gav1ndica
Drives: BMW X3 (F25)
Just received this today as well on a 2015 28i @ 100k, chassis stabilization warning with ABS. Codes D017A3, D017C5 and 480715 indicating front right wheel speed sensor
      05-18-2024, 05:24 PM   #8
kurtlover
Drives: BMW X3 2014
Have you got the same issue back after? My today's issue looks the same as popped up ABS, parking brake while could drive about 65 miles after the indicators.
