      12-17-2014, 02:13 PM   #1
drodnyc
drodnyc's Avatar
20
Drives: 2019 BMW X7
need help in clarifying something
I probably read most, if not all, of the posts regarding DHC, DDC, VDC, sport suspension delete, etc, etc.
I know the differences and I'm not looking to start another DHC pros/cons conversation. This is totally different.
If someone does not select Dynamic Damper Control as an option, or DHC/VDC what is the outcome as far as labeling is concerned? I mean, will it say "standard suspension" on the build/sticker list?
and what option and/or selection, or deselection, generates a "sport suspension delete" line item?
on two separate accounts, on separate vehicles, I have seen one example of each line item. But never both on the same build sheet.
is there a difference or is it two ways of saying the same thing? (ie did not select DDC)
2019 BMW X7 M-sport
2017 Harley Street Glide Special
2018 Triumph Bobber Black
      12-17-2014, 02:36 PM   #2
drodnyc
drodnyc's Avatar
20
Drives: 2019 BMW X7
BTW,
what I believe is:
if you opt for M-pkg and do not want DHC, you will get "standard suspension"
if you opt for M-pkg, and do not want DHC, and do not want the standard suspension, you must select "sport suspension delete"
so, what exactly is "sport suspension?" is it the standard suspension that comes with the base model, or is it sport suspension that you get with the m-pkg? (which I don't believe)
2019 BMW X7 M-sport
