      11-29-2014, 06:53 PM   #1
Razor1973
Razor1973's Avatar
Drives: 2012 BMW 535i M Sport 6MT
Unhappy Help me identify what's melting in my engine bay
I started smelling burnt plastic in the cabin while driving today and, since it started getting pretty bad, I just pulled up, realized smoke was coming out of my engine bay, popped the hood open and found this. It's dark out and you can't really see that in this photo, but something around the top edge of this cylindrical part is melting. It looks like black plastic. Any idea what this part is, what could be causing this, how bad it is, how it can be fixed, what it'll cost me and whether it's "safe" to drive the car this way?
Thank you!
Current: 2012 535i M Sport 6MT + 2019 Volvo XC60 T8 Inscription (PHEV)
Past: 2011 BMW X3 xDrive35i, 2008 BMW 535i 6MT, 2009 BMW 335i sedan 6MT, 2007 BMW 335i sedan 6MT, 2007 Volvo S80 V8 Sport AT, 2005 Volvo S60R 6MT, 2001 Audi S4 6MT, 1998 Volkswagen GTI VR6 6MT
      11-29-2014, 06:59 PM   #2
mge92
SPEED RACER
mge92's Avatar
Drives: BMW X5 M50d BMW M2 CS
Do you have any other shots?
      11-29-2014, 07:08 PM   #3
Razor1973
Razor1973's Avatar
I don't, but have already identified the part at least, thanks to RealOEM.com. This is the catalyst, seen here. I wonder if this is a common problem.
I kept searching and found this thread that may explain it.
It looks like the part goes anywhere from $1,000 to $1,500, plus labor and my warranty just expired a few months ago Not looking forward to a replacement, so I'm hoping it can be repaired. I will need to wait till Monday to take the car to a shop, though.
This is obviously frustrating.
      12-05-2014, 10:32 AM   #4
Razor1973
Razor1973's Avatar
OK, so I finally took my car to the dealership Service Department and they just called me to let me know they found and fixed the problem. They said it was the valve cover that was leaking oil onto the precat and not a problem with the precat itself. They said they replaced such valve cover. Valve cover? What could they be referring to? It has to be something right under the engine on the passenger's side, right above the precat.
      12-05-2014, 11:30 AM   #5
Radioactive
Drives: '11 X3 28i '10 535i '04 325i
Well, they're referring to the cover for the valves. Under the engine glamour cover is the access to the spark plugs and valves amoung other things. The valve area is full of oil during operation. On cars i have worked on two things will cause the cover to leak; bad seal ie gasket and/or poor torquring of valve cover bolts. Leaking sometimes on other parts. Haven't taken my X3 apart yet,LOL, so i'm not exactly sure of their setup. Since they replaced the whole cover rather than just the gasket, i wonder if cover was bent, or is the seal part of the cover. if it has a separate gasket, was the dealer just too lazy to remove the old gasket from the cover. Still kinda early to leak, have a 325i w/ 105k miles and valve cover is just starting to leak.
      12-08-2014, 01:34 PM   #6
Razor1973
Razor1973's Avatar
Thanks. Even though my warranty just expired, BMW NA agreed to a goodwill repair and covered the part to replace. The dealer charged me for labor. Total was just above $300.
