      09-02-2011, 09:41 PM   #1
Amanda_E
Drives: 2011 X3 28i
TPM Error Message
I just took delivery of my 2011 X3, went to the BMW performance center to pick it up. (It was so fun!)
On the drive back home from South Carolina to Texas I had an error message pop up 6 times that I had a tire pressure monitor malfunction.
It happened 6 times in two days. The first day just once and the second day five times in about two hours.
Has anyone had this issue? I am going to take it into the shop tomorrow but it's just kinda crazy that I finally got home from delivery and this happened.
Any insight would be incredibly appreciated.
Thanks y'all!
      09-02-2011, 10:01 PM   #2
Le Chef
Drives: BMW X3 35i
Did you check your tire pressures with an external gauge? Make sure you check when the tires are cold. If they're at the recommended pressures in the manual, reset the TPM as per instructions. If after that you still get errors then visit your dealer.
      09-02-2011, 10:16 PM   #3
Amanda_E
Drives: 2011 X3 28i
Thank you! I will do that, I didn't check the pressure yet but will tomorrow.
