      02-16-2017, 10:45 AM   #1
jagr
Drives: BMW X3 3.0sd
X3 E83 Xenon Retrofit Complete
Finally finished my E83 Xenon retrofit.
It makes a huge difference as I can now see where I am going.
Quite a bit of work is involved and not a cheap process but worth it in the end:
Before:
During:
Finished:
      02-16-2017, 09:24 PM   #2
Jc11
Around how much did spend ?
      02-17-2017, 02:35 AM   #3
jagr
Approx:
£700 Light units
£150 Genuine BMW ballasts
£100 Osrsam D1s bulbs
£20 Angel eye LED bulbs
£20 Cabling and Connectors
As you can see I could have saved £150ish if I had bought cheaper bulbs/ballasts.
      03-18-2017, 10:50 PM   #4
campaign308
Drives: 08 X3
Is taking pretty much the whole front end apart required to complete this task ?
      03-19-2017, 07:04 PM   #5
jagr
Yes.
It isn't that difficult to remove the bumpers on X3's. I fitted a detachable towbar last year.
The most difficult part is the effort required to pull the bumpers away, it isn't natural to pull that hard on plastic but nothing was broken doing either jobs.
      10-29-2018, 12:14 PM   #6
tjag1124
Drives: 2004 x3
I am interested in doing this for my wifes x3. How does the wiring work? Does wiring need to be altered in order for them to plug in to the wire harness?
      07-27-2019, 11:01 PM   #7
bintoro
Drives: BMW X3 e83
Hi, greetings from Indonesian e83 X3 owner
It seems to me that you installed the e83 X3 LCI front headlights to e83 X3 non LCI? Is that correct?
Tags
e83, retrofit, xenon
