      04-19-2012, 02:45 PM   #1
Teemo Panda
*Bimmerpost Plasti Dip Guru*
Teemo Panda's Avatar
Drives: E53, E46-M3, E70, F25-X3
2013 BMW X3  [5.66]
Instrument Cluster Hidden funtions?
So guys, i was browsing to youtube on the f25 instrument cluster but i was directed to a f10 which was similar to the f25.
I saw that the instrument closters hidden functions could be ultilized if unlocking it by placing ur last 7 digits of the vin.
There you could see your gas tank left, test control, your rev counter and more importantly, YOU COULD SEE THE ERROR CODES without placing anything into the obd. And many others.
So i was wondering, if i were to unlock my f25 instrument to ultize this functions, would this void my warranty?
Thanks!
      04-19-2012, 02:56 PM   #2
jk
Drives: '12 x3 35i
if you don't get an answer here, you might post it in the "ask a dealer" forum at bimmerfest.com. btw, where/how does one enter the numbers?
      04-19-2012, 03:04 PM   #3
Teemo Panda
2013 BMW X3  [5.66]
I didnt knwow at all there was a dealer section. Thanks for the info.
Btw, about the inputing of the vin. I believe there is a 7 code scroll down of numbers and letters
      04-19-2012, 04:33 PM   #4
Bustofa
Drives: F25 X3 XDrive20D SE
Try this:
http://x3.xbimmers.com/forums/showpo...27&postcount=8
      04-19-2012, 05:49 PM   #5
Teemo Panda
2013 BMW X3  [5.66]
Ok i tested this and everything went fine.
Thanks for all ur input guys.
The only problem is, if ur going to foundle with the instrument cluster it would be locked and you would have to put in the code again. It wont stay unlocked.
But anyways, im happy that i could access the error codes without buying special equipment.
