01-04-2021, 07:01 PM | #1 |
Rep 383
Drives: 16 X3 28d/18 540d xdrive
Need Part Numbers
I've searched at least 6 online sights selling BMW parts and have yet to see this part pictured in any exploded view of parts for an F25. Specifically, I am trying to find part numbers (right and left) for the small rubber splash shields affixed to the lower front portion of the vehicle's rear wheel wells. There is one on each side and the visible portion of this rubber shield extends about 2" below floor pan and is about 6" wide. I say visible, because the upper portion of the shield is fastened under the leading edge of the F25"s rear fender liner. In my case, one of these shields has broken off flush with the floor pan, while the other one has a hunk missing from it.
Any help with this is appreciated. |
01-04-2021, 08:52 PM | #3 |
Rep 383
I will give it a try. Thanks
01-05-2021, 10:18 AM | #4 |
Rep 383
The recommended site is great. Found items in one exploded view and they are called Deflectors (Left and Right) with part numbers 5167213651 and 5167213652 respectively. However, when these numbers are entered on several online parts sites, they cannot be found. Also tried google, amazon and ebay without result. I suspect that these must be ordered from a BMW dealer, something that I'd like to avoid. Well at least I have the BMW part numbers, so thanks for the tip.
evilchargerfan270.00 |
01-05-2021, 05:44 PM | #5 |
Rep 2,551
That's because you have a typo in your part number
https://www.fcpeuro.com/products/bmw-deflector-lip-rear-left- 51627213651 https://www.fcpeuro.com/products/bmw...ht-51627213652 |
01-05-2021, 06:49 PM | #6 |
Rep 383
Thanks for your research. I should have considered FCP as I once did a lot of business with them as a Volvo owner. I am really surprised by the company's huge inventory of BMW parts.
