      01-03-2021, 03:10 PM   #1
Dan9
Drives: BMW 325i Touring, BWM X3 F25
Evap leak 2013 N20
Hi all,
First post here and hoping for some help sorting out a P0456 small leak in the evap system on my 2013 X3 with 48,000 miles.
Seem to be going down the rabbit hole with this one. Here's what I've already replaced/ done:
- Smoke test performed, no visual leaks found
- Fuel cap replaced
- NVLD pressure switch/ module replaced
- Purge valve and associated hoses replaced
- Charcoal canister/ filter replaced
Since all of this work performed I've driven the X3 nearly 500 miles and retrieve a pending and permanent stored P0456 code with no CEL.
Open to any and all advice or help, thank you!
