      03-02-2024, 09:32 PM   #1
jfrichtl
Drives: 2011 X3
Hi, I searched several threads on tpms module replacement and couldn’t an exact answer on coding. If I purchase a used sensor that has the same software number will this need to be coded for my car? 2011 x3 2.8 x drive
      03-03-2024, 09:32 PM   #2
duperdog
duperdog's Avatar
Drives: E46 M3, F25 xDrive28i
I bought one with same software and did not have to do any coding.
      03-04-2024, 07:48 AM   #3
deyrag
Drives: x3 2.8i
New or used?
      03-04-2024, 07:50 AM   #4
duperdog
duperdog's Avatar
Originally Posted by deyrag View Post
New or used?
Used from eBay.
      03-04-2024, 12:33 PM   #5
ClutchFC
Drives: X3 35i
You will have to update it unless for some crazy reason you luck out and it works without. Won't truly know until you plug it in..
      03-08-2024, 06:27 AM   #6
LikeNo1
Drives: 2017 F25 X3 LCI x20d Msport
Right: on my f25 lci tmps module on the lower back side surprise was absent (and TMPS and RDC coded like disabled); searching on RealOem for the part number, buyed one like new from Spain, installed and coded because system wan't saw it. Coded by myself via esys worked like a charm.
